Question about GE 7-4853 Clock Radio
How to use the snooz button - GE 7-4853 Clock Radio
Lost instructions for LOGIK LCRIP12 Portable Clock Radio
1. In AUX mode press and hold the SNOOZE/SLEEP button an then press the SNOOZE/SLEEP button to select the 12 or 24 hour time format in the display. Press and hold the SNOOZE/SLEEP button or wait 5 seconds and the time format will default to your latest time format selection and the time format will be confirmed.
2. In standby mode press the TIME button. The hour digits will flash in the display.
3. Press the <--- ---> buttons to adjust the hour digits and then press the TIME button to adjust the minutes.
4. Repeat step 3 for the minute digits and then press TIME button to confirm the clock setting.
Hope this helps
Cole.
colecats28@gmail
Mar 31, 2013 | Audio Players & Recorders
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
Oregon Scientific RRM326P Snooze button won't work with radio
this is internal speaker control volume defect, please send to repair shop for repair.
Nov 29, 2009 | Audio Players & Recorders
Times Indiglo Nature Sounds Clock Radio T466W
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Nov 19, 2008 | Timex T276B Clock Radio
Manual RCA RP3710A
For the snooze, hold down the snooze button (should display the length of time for snoozing) and hit the time/tune buttons up or down to increase or decrease the snooze time.
For the nap time, press nap and the nap indicator should start blinking. Again, hit the time/tune buttons up or down to increase or decrease the name time in 10 minute increments up to 2 hours.
Oct 21, 2008 | RCA RP-3765 Clock Radio
How do I set the sleep timer?
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
Oct 01, 2008 | Homedics SS-4000 Clock Radio
Snooze is not long enough
Keep the sleep button pressed and use the FF/slow button to increase or decrease the time for snooze
Apr 16, 2008 | Zenith Z124B Clock Radio
GE 7-4853 Clock Radio Logo
22 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
