Question about Barkan Tilting Wall Mount for 50 to 65 inch Flat Panel TVs 61-41
Model 61 How do you mount to wall? I did'nt have the instructions in the box
Rca manual instruction
"RCA manual instruction" is not a model number. But as long as the TV has wall bracket fixing holes and a removable table stand then yes, it can be wall mounted
Sep 03, 2014 | Televison & Video
Tip
Milestone AV Technologies Recalls Television Wall Mounts Sold Exclusively At...
NEWS from CPSC U.S. Consumer Product Safety Commission Office of Information and Public Affairs Washington, DC 20207 FOR IMMEDIATE RELEASE
January 27, 2009
Release #09-105 Milestone’s Recall Hotline: (877) 277-3707
CPSC Recall Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
Milestone AV Technologies Recalls Television Wall Mounts Sold Exclusively At Best Buy; Unit Can Crack, TV Can Fall On Consumers WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed.
Name of Product: LCD television wall mounts
Units: About 140,000
Manufacturer: Milestone AV Technologies, of Savage, Minn.
Hazard: The wall mount can crack when used with televisions 26 inches and larger or with televisions that include a DVD player. The television can then fall from the wall mount and pose a serious risk of injury to consumers standing nearby.
Incidents/Injuries: Milestone is aware of 28 incidents in which the mount has cracked and the television has fallen from its mount. No injuries have been reported.
Description: These wall mounts are used with flat screen LCD televisions. The recalled wall mounts are INIT models NT-TVM103 and NT-TVM104. The model numbers can be found on the UL sticker on the television interface.
Sold at: Best Buy stores nationwide from June 2007 through December 2008 for between $60 and $90.
Manufactured in: China
Remedy: Consumers should immediately stop using the wall mounts and contact Milestone to receive a free repair kit.
Consumer Contact: Call Milestone toll-free at (877) 277-3707 between 7 a.m. and 7 p.m. CT Monday through Friday or log on to the company’s recall Web site at www.milestone.com/initmount
on May 21, 2009 | Insignia LCDTV26 26 in. Television
WHERE ARE THE BOLT FIXINGS ON THE REAR OF THE T.V
If they are there they should be hard to miss--Google the model number for the owner "manual" or if you have it read it. Most not only show the mounts but where they connect to the set.
May 20, 2012 | LG 42LB1D 42 in. HD-Ready LCD TV
How do I wall mount the phone
Most new phones come with a special wall mount bracket included in the box.
If you no longer have this bracket then you may be able to order a new one similar to the one advertised at the following link:
http://www.nec-dsx.com/nectewamokit.html
Good luck.
Joe.
Nov 22, 2011 | Lands Phones
The instruction manual does not include instructions to use this as a wall-mounted phone.
Hi..
There will be any instructions regarding a wall mounted phone unless it is of that kind.... It the mobile that you have can be used as a wall mounted , and still instruction missing. kindly send the model number of your phone. and i shall guide you through
thanks for rating
May 30, 2011 | Cell Phones
What is the weight of model TX-42F430S Television. I am mounting it on the wall. Thank You!
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Jan 25, 2011 | Westinghouse Televison & Video
Can i mount my tv on the wall it is model cwf32l6
Yes you can.
there are many types of wall mounts you can buy. Ensure the load / weight rating of the wall mount exceeds that of your TV, and mount it exactly as per the manufacturers instructions.
Most audio visual shops sell all types of wall mounts.
You can also check out ebay.
Feb 28, 2010 | Symphonic ST419E TV
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
HOW DO YOU REMOVE THE BASE OFF THE MODEL #46XPV540U?
The optional "Wall mounting Kit" has the instructions inside the box....take the model number of your TV to the place you bought it and get the KIT.
Jun 27, 2009 | Toshiba Televison & Video
Barkan Tilting Wall Mount for 50 to 65 inch Flat Panel TVs 61-41 Logo
Top Barkan Televison & Video Experts
Electro Med Services...
Are you a Barkan Televison and Video Expert? Answer questions, earn points and help others
