Question about Jenn-Air Kitchen Ranges
How do I remove faceplate on Jenn Air S136 electric range? I need to replace the element switch which is mounted on the back side of the faceplate.
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Posted on Nov 27, 2009
EllaWatson25
  • 725 Answers
SOURCE: heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Posted on Jan 07, 2010
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a Jenn Air S136 range/oven downdraft. The
Kindly provide few more details :-
1. when did you use it last time?
2. How old is the unit?
3. Is it completely dead or shuts off?
4. Do you have any error message on the screen?
5. Have you disconnected the power supply for 5 minutes and then turn it back.If not, try and see, if that helps.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
Having problems with self cleaning my Jenn Air model S136 can you give me step by step instructions
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 05, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Replaced lower element after short
They are generally mounted to the rear of the oven with screws. Not all ovens have them. Please post the complete model number from the range and I will try to help you find the problem.
Thanks/mike
Jan 14, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Heating element in my electric Jenn-air oven
Just contact us at:
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
How do you remove old bake elementfrom Jenn Air SVE47001
Pretty simple, make sure you unplug the range or flip the breaker off. Remove the two screws mounting the element to the back wall, carefully pull out the element. It probably has slide on connectors, pull them off and thats it! If you accidentally pull off a wire and it stays back in the stove, you can pull the unit out and remove the back panel and it will be all out in the open.
Jun 17, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Selector to Clean
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
49 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
