Question about Emerson Microwave Ovens
Microwave only works when door is open - Emerson Microwave Ovens
  • Emerson Master
  • 9,098 Answers
See these help files: http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on Oct 17, 2013
My microwave keep working when I open the door and it is stopping when I close the door.Then working normal but I cannot keep my door open, it keeps running. What can I do??
First, It is very very dangerous for a microwave to run with door open. The door is also a shield to protect you from the microwave radiation. There should be a safety interlock to prevent this from happening. DO NOT USE the microwave! Seek out professional repair or replace the unit.
May 20, 2015 | Microwave Ovens
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Microwave makes noise after door is opened jenn air model jmv9169ba
Microwave ovens emit powerful radio waves and in general for safety reason should only be used when in perfect working order. It usually costs more to repair an older microwave oven than to simply replace it.
Suggest buy a new one.
Mar 02, 2018 | Jenn-Air JMV9169BAS Convection Microwave...
Microwave works while door open
Replace. Microwaves are cheap.
Feb 16, 2018 | DCS Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 27, 2013 | Microwave Ovens
Microwave starts on its own when microwave door opens.
see this adjustments. God bless Oherwise the main control board can be defective.
Oct 03, 2012 | GE Microwave Ovens
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
Turntable goes around when the door is open and the microwave is off.
Do not run the microwave with the door open. You will be cooked. Sooner or later, if there are enough microwave ovens, (and there are), everything that can go wrong with them will, eventually. There are several interlocking safety systems built into every microwave so that they won't work with the door open. Yours may have failed. I've never come across one, but that doesn't mean it can't happen.
It may only have a fault making the fan and turntable operate, which can sound like it's working with the door open. Either way, get it checked or get a new one.
This assumes that the microwave isn't actually supposed to do what it is doing under normal conditions or current programming. Refer to manual/instructions if unsure.:::Spiceweasel.au
Apr 03, 2008 | Kenmore 80809 Microwave Oven
Door opener not working
The door latch must have broken in side which had stucked the door does not allow to open. Please arrange to call service engineer from the maufacturer's service center to fix the problem as proper alignment of the latches is must for safety measures.
Aug 01, 2007 | Whirlpool GT4175SPS Stainless Steel 1200...
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Nov 07, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
