SOURCE: keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
SOURCE: keyboard problems with samsung nc10 netbook
I just had the same problem and found the solution on here. press the fn key and the numlock key which on mine is the F11 button so i assume its the same on yours. hope this helps.
look in bios, for numlock boot
thats why the number function works instead of the letter,
just got 16 odd at work and its my job to put xp pro on, with out a cd drive, if u need xp pro or another os hit me bk
SOURCE: KEYBOARD PROBLEM
Was there any liquids spilled inside the keyboard? You may need to have the keyboard replaced as they start to fail in due time.
SOURCE: MY SAMSUNG NETBOOK NP-N130 HAS
Try to re-enable the startup programs. You don't need that program to enable start-up items. However, you will need to do some digging to find out exactly WHAT has been disabled. Otherwise, you have no other choice BUT to do a clean install, or revert to your last backup. Those options are way more trouble than reinstalling software.
Just follow these steps:
