Question about LG HBS-700 Bluetooth Headset
Left earbud has no sound - LG HBS-700 Bluetooth Headset
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 41 Answers
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
Left earbud has no sound - 3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out Left earbud has no sound - 3dd35676-1c86-449a-9cea-c6cfe284e270.jpga.net/uploads/images/3dd35676-1c86-449a-9cea-c6cfe284e270.jpg" alt="3dd35676-1c86-449a-9cea-c6cfe284e270.jpg" class="h_mi" />
I hope this solution was helpful
Posted on Oct 23, 2013
  • Kezz
    Kezz Jul 09, 2014
    I recently created a full repair video for this
  • Anonymous Jan 03, 2017
    is it possible to open the earbud itself without destroying it? my earbud works fine when the wire is wiggled near the bud, so i assume i can solder the loose wire back into place IF i can get the bud open. does it just pry open?
    New Friend:
There may be a simpler solution. Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I was about to throw mine in the trash, but I removed the mesh and my LG Tone+ sounds like new again.
Posted on May 04, 2016
  • 2 more comments
  • John Holliday
    John Holliday Sep 05, 2016
    Fantastic tip! I had already replaced one set and was just about to toss them. On my LG HBS1100, there is a silver mesh that is adhered with a tiny glue ring. Underneath that, there is a black cylindrical plug. Using a needle, I removed the plug, then replaced the glue ring, silver mesh and the rubber earpiece. Voila! High-fidelity sound again. Thank you!
  • Jeffery Noland
    Jeffery Noland Oct 04, 2016
    I was going to put my set on the "future projects" pile to try replacing the earbuds, but I tried Thomas' suggestion and that did the trick! You da man! Mine were 1 month out of warranty and I was pretty upset. Thanks much!
  • Jonathan Shaw
    Jonathan Shaw Dec 14, 2017
    I have LG TONE Pro /HBS-770 my right ear piece volume is very low compared to the left thank you very much, I did what you said but I also put the plug whatever it is thats in behind the mesh back in. First pulled off glued mesh and grabbed the black foam thing that was protecting the speaker pulled it out, instantly back to normal so I put it back in to see if it went back to low volume but its still .working like new
  • Anonymous May 10, 2018
    My HBS 910 left stopped working when I cleaned earwax on the left side. I used Thomas' suggestion and used a pencil to push in the mesh and scoop it out. This immediately fixed the sound and got it working again. Thanks again! I was about to throw them out!!
    New Friend:
This was very helpful.. is there a link you can send me of a place to purchase the replacement ear bud and wire like the original?
Posted on May 03, 2015
  • Kezz
    Kezz May 03, 2015
    No, unfortunately I don't know where to purchase the original earbuds. You can use almost any earbuds tho. Just need to add a magnet to the back.
    After I originally posted this fix, I made a few youtube videos on how to fix it. Search my channel "Kez3000" to see them.
  • Kezz
    Kezz Mar 31, 2016
    https://youtu.be/UhFEuRD0vAA
The left earbud of my new headphones wont work
Che k the end of ur headphone jack also check where its being put into possibly to rule out its not faulty headphones i sugest try them on something else then u can rule that out
Oct 28, 2017 | Sony Audio Players & Recorders
Volume in left earbud is suddenly very low
just do the volume the equalization. Once the Bluetooth is on just click the volume (+) until you hear a beep then click volume (-) until you hear a beep, this should equalize your volume. and give you equal sound from both of you earbud.
Oct 17, 2013 | LG Tone HBS-730 Bluetooth Headset- Black
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
Aug 28, 2009 | Audio Players & Recorders
Left earbud problems
Well, I had the same problem with the right earbud. Luckily I was under warranty with Target, so they told me to contact Bose. I did and they had me send in the headphones (to make sure I waas telling the truth) and about 2 weeks later I got my earbuds back. Their customer service is excellent, so that's what I would reccomend
Aug 09, 2009 | Bose in-ear headphones - Black with...
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
Sweat got into earbud- sound very faint
That happens because the water and saline solution in the sweat are causing the wires inside the earbud shorting to each other, or shorting to the earbud casing that is grounded.
Let the earbud dry out in few hours or more, if the problem does not go away, then get replacement heaphones, it means that oxide formation on the contacts is causing a short.
Do not use shorted hearphones they can cause damage to the connected device.
Regards.
May 04, 2009 | Shure SE530PTH Professional Headphones
Sound in left earbud shorts in and out
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
Mar 02, 2009 | Etymotic Research Isolator ER-6i Consumer...
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
LG HBS-700 Bluetooth Headset Logo
10,198 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
