Question about Canon PIXMA iP4300 InkJet Photo Printer
My canon ip4300 wont do anything when trying to clean or print it just says it's in ERROR mode please help x
    Problem Solver:
  • 5 Answers
It may have lost track of where the head is, even though it calibrates when starting up. (Like when you remove jammed paper forcefully).
First check: make sure the front flap used to print a cd is closed - it tends to come loose easily.
If that isn't the problem, then:
Switch the printer on. When the head comes in view, remove the power plug. Then move the head all the way to the left. Close the cover. Put the power plug back in and switch on.
Posted on Nov 03, 2013
svenby
  • 66 Answers
SOURCE: canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Posted on May 22, 2008
ozmal
SOURCE: printer
A support tech at Canon suggested I try this.
find the file ImageCache.ic - I found it in application data folder in My Documents, delete it.
Uninstall CD Label Print, search for any other "CD Label Print" files or folders and delete them too.
Re-boot and re-install CD Label Print.
This worked for me. Hope it works for you too.
Cheers
OM
Posted on Dec 02, 2008
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
  • 17 Answers
SOURCE: Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Posted on Feb 18, 2010
  • 37 Answers
SOURCE: canon IP4300 flashes orange and green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
The orange light on pixma iP4300 is flashing 5 times. I have cleaned the printhead (gold contacts) with alcohol PJ
Use cotton swabs dipped in hot water or a mixture of hot water and isopropyl alcohol
Use it to clean the print head and the electronic contacts on each ink cartridge
Once done, allow to dry and try again
If the error still persists, you have a damaged print head which needs to be replaced with a new one
Hope this help!
Sep 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4300; new printhead and PGBK ink cart but it won't print
call ok canon 800 number..their better than India CAll centres.
Dec 03, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon IP4300 flashes orange and green
Oct 25, 2009 | Canon BubbleJet i560 InkJet Printer
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
Oct 07, 2009 | Canon Office Equipment & Supplies
Canon ip4300 Error code 1300
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon iP4300 service error on my printer
dear
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. <a href="http://www.concordsupplies.comhttp://www.concordsupplies.com">http://www.concordsupplies.com</a>
May 28, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
37 people viewed this question
old marine
old marine
