Question about Dell Latitude E6500 Laptop
Find mac address though safe mode - Dell Latitude E6500 Laptop
I'm using a mac with 10.9.2, and when I'm using Excel, the screen jumps around - it's very annoying when I'm trying to manipulate the data - please help!
Startup your Mac in Safe Mode
A Safe Mode boot takes much longer than a normal boot so be patient.
Once you are in Safe Mode, click Restart from the Apple menu.
Then see if the issue persists.
Mar 03, 2014 | Computers & Internet
I find 2 strong open signals but after saving them, I cannot connect to Internet in wireless mode to those open network addresses (the TL -WA5210G is connected directly to my notebook, DHCP auto mode is...
Incase Open networks are configured for MAC authentication(MAC binding) then you might not be able to connect to those networks. Even though Network is Open (Unsecured), if ACL (Access Control List) is enabled on the network then only those computers can connect whose MAC address is configured for that Network, its another Security feature on Routers.
Try connecting to some network which your are sure are Open (Unsecured)
Jul 06, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
How do I get rid of the grey screen with a ? File flashing
That usually means the hard drive is bad, but in some cases, reinstalling Mac OS will fix it...or you can boot into Safe Boot (Safe Mode for Mac) by holding the 'Shift' Key when you turn the computer on...If the safe boot doesn't work, try Single User Mode...
Hold Command + S when you turn your computer on (a black screen with white text will appear)
When all of the code mumbo jumbo stops loading...type (exactly like this) /sbin/fsck -fy
this will run a filesystem check and maybe fix the operating system if that is the problem, but like I said, that usually means the drive is bad...good luck though :)
Apr 24, 2011 | Apple 13" MacBook Notebook Computer ...
My Samsung CLP 310 won't come out of sleep mode preventing me from printing. How do I wake it up. There's nothing in the manual or in Samsung's troubleshooting guide.
I finally got my CLP325W waking up correctly from sleep, but I made a few changes at once and don't know for certain which one (or combination) worked. Here are my changes:
1. disabled the USB port. (I had originally set up the printer via this port).
2. disabled IPv6 support.
3. disabled the dynamic DNS registration.
4. enabled telnet (though I doubt this had any effect).
My setup uses a static ip address that is outside the range of the dynamic addresses my router assigns and I use a mac filter on my router without any problems.
Apr 29, 2010 | Samsung CLP-315W Laser Color Printer
The circular timer startup screen NEVER STOPS! Powerbook G4
Hi
Safe Boot is a special way to start up in Mac OS X 10.2 or later when troubleshooting. Safe Mode is the state Mac OS X is in after a Safe Boot. To perform a Safe Boot, hold the SHIFT key as your Mac starts up.
Some features don't work in Safe Mode Safe Mode can be useful for troubleshooting. However, certain Mac OS X features do not work in Safe Mode. For example, you can't use DVD Player, capture video in iMovie, use audio input or output devices, or use an internal or external USB modem. The behavior of some devices such as an AirPort card may vary depending on computer and Mac OS X version.
Safe Mode in Mac OS X 10.5 or later also disables Quartz Extreme (hardware accelerated graphics). Applications that depend on Quartz Extreme will not open, and the Mac OS X menu bar will appear solid even if "Translucent Menu Bar" is enabled in Desktop & Screen Saver preferences.
Aug 03, 2009 | Apple PowerBook G4 Mac Notebook
Same problem!
I would boot the computer in safe mode and here is the instructions.
Learn how to start up in Safe Mode.
Products Affected Mac OS X 10.4, Mac OS X 10.3, Mac OS X 10.2, Mac OS X 10.5
To start up into Safe Mode (to Safe Boot), do this:
  1. Be sure the computer is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
  4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
while your in safe mode see if you can uninstall the drive software and reinstall it
Jul 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My mac mini gets stuck on the first screen (gray with the Apple logo and the spinning wheel) and won't continue loading.
Start here...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Jan 29, 2009 | Apple Mac Mini Desktop
Mac Desktop Troubles
please delete the font cache on your system by restarting the computer in safe mode.
you can do this by holding down the shift key when restarting the machine.
this would launch the computer in safe mode.
once its started in safe mode then restart the machine in normal m,ode(Without the shift key) and then check the results
Nov 19, 2008 | Apple Mac OS X 10.4 Tiger for Mac
''Nonresponsive Script''
Try "Firefox Safe Mode". If the problem goes away, disable your extensions, one by one.
How to start Firefox in Safe Mode
  1. Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Exit menu item.Close down Firefox completely: On the menu bar, click the Firefox menu, and select the Quit Firefox menu item.Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Quit menu item.
  2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode). Firefox 3, Mac OS: Hold down the Option key, as you start Firefox. Firefox 2, Mac OS: Go to the Utilities directory (in the Applications folder) and open Terminal, then run:/Applications/Firefox.app/Contents/MacOS/firefox -safe-modeGo to your Terminal and run:/path/to/firefox/firefox -safe-mode
  3. Firefox should start up with a Firefox Safe Mode dialog.
Nov 17, 2008 | StumbleUpon Social Network
MAC wireless mouse does not move cursor
Have you tried in safe mode?
Please check in safe mode, If the mice works then re-install os by selecting archieve and install.
Make sure to select the preserve user data tab while performing re-installation.
Dec 14, 2007 | Apple Mac mini G4 Desktop
Dell Latitude E6500 Laptop Logo
54 people viewed this question
Alun Cox
