Question about Newpoint Computers & Internet
Anybody know where I can download the monitoring software for a Unitek Office 400 UPS?
What power plug do i use with unitek data hdd docking station
The Y-2041 comes with a 12V 4A power supply which is not quite as large as the typical laptop supply. It is manufactured by Ktec and the model is KSAH1200400T1M2.
Jan 19, 2014 | BestOfferBuy Unitek Y-2041 USB 2.0/eSATA...
Hi i have message appear on pc screen says ( UPS communication cannot be started error 4304 setup connection failed ) all what i did i jut replace the battery
you mean on your PC UPS monitoring software? Try to off and on your UPS and try to open your monitoring software. or try to double check your connection from UPS to PC.
Mar 21, 2012 | AEG Computers & Internet
GT 400 PC suite - where is it. CD did not come with phone, cant find it on the LG site. Downloaded update software & it doesn't recognise tjhe phone. I'm getting very frustrated**%##&^%$#@
Im having the same problem, ive purchased a gt400 and it didnt come with a instalation disk/pc suite thing. Ive downloaded the update software from Lg website but it seems to have every install usb driver accept for gt400. Does anybody know how i can install the phone/pc suite thing to my computer?
Oct 25, 2010 | Computers & Internet
How do I eliminate these annoying little pop up screens on my monitor when something is printing? I know what my ink cartridge levels are, so I don't need these pop ups. Help
You could delete the printer monitor from your startup folder.
Either use Msconfig / startup or download CCleaner and use the startup editor built into the tools.
While your there, you can remove / disable other un needed items, like office / adobe acrobat / google / flash / most of these items apart from your security software do not need to start when windows starts.
Sep 04, 2010 | Office Equipment & Supplies
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
My office 2007 is not having product key please provide any key
You mean you downloaded it illegally?
There isn't another legal way to obtain a key, apart from purchasing the software online, or from a shop. Then you will get a product key.
Jul 07, 2009 | Microsoft Office Professional 2007 Full...
I have a fellows UPS 425AP
You don't need software unless you want to use the monitoring and outo-shut-down features. Try this location for the software:
http://www.fellowes.com/Fellowes/Materials/Software/UPS_MON.exe
Here is the page to find info on this software:
http://www.fellowes.com/Fellowes/site/support/support_softwaredrivers_mediaface.aspx
Jan 03, 2009 | Fellowes 99052 UPS 425VA Battery Backup...
The monitor goes into power save mode and the ups disconnect
It should work, make sure each profile is set the same way. Keep in mind you should still be able to utilize your standby feature, and your screensaver as well.
Nov 13, 2008 | Belkin (F6C800-UNV-PL) UPS System
Computers & Internet Logo
55 people viewed this question
Top Newpoint Computers & Internet Experts
David Payne
David Payne
Are you a Newpoint Computer and Internet Expert? Answer questions, earn points and help others
