Canon ir 2570 error code e000021-001 - Office Equipment & Supplies
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
SOURCE: Error code E000020 - 0081 in ir C3170 PCL5c
Posted on Jun 04, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How can i identifying canon printer ir 2570 ci on my computer ?
What operating system are you using? Can't really help you without you giving us some more details, please.
May 05, 2014 | Canon Office Equipment & Supplies
Canon ir 2570 error code 7356
The printer knows if it needs paper by a sensor. Usually this is is a light beam across the paper supply. Both ends, the light and the sensor can get covered in dust and may need to be cleaned
Apr 27, 2014 | Office Equipment & Supplies
E351-0000
E351: Error PCB ECO. Communication error between the PCB and the PCBECO main driver during startup.
Turn off main power and check the main controller PCB (primary, secondary), thenturn the main power.
Check in the back of the machine the main controller PCB (Main) make goodconnection with the PCB ECO-ID: help with image processing.
Hoping this is helpful message ... GOOD LUCK
Apr 28, 2012 | Canon Office Equipment & Supplies
Canon IRC 2570 IC Error Code is E000012-0002 problem what is the solution
May 22, 2011 | Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
67 people viewed this question
k24674
jasbo
jasbo
