Question about Tunturi Exercise & Fitness
Treadmill motor control board
Can you tell me where I can purchase a motor control board for a Tunturi T60 Treadmill? Thanks
    Top Expert:
  • Tunturi Master
  • 12,223 Answers
Go to www.fitnessrepairparts.com and get it.
God bless you
Posted on Oct 18, 2013
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
  • 13 Answers
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Posted on Jul 29, 2010
Put a Tunturi t60 control motor board back together
What do you want to know .
Send a pic if u like and I will tell you how .
Darren
May 14, 2015 | Tunturi T60 Folding Treadmill
System check failure
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
Mar 30, 2014 | Tunturi T60 Folding Treadmill
Treamill shows' Motor Overload' after a couple of seconds of operations
see the video attached. lube the rollers brearing front and back too.
test the terminal motor voltage with VOM, if there are the motor is faulty.
test the output voltage control board for input voltage terminal motor, if there are NOT voltage the board is faulty. See my personal TIPS.
God bless you
Oct 11, 2013 | Tunturi T60 Folding Treadmill
Tunturi t7 showing error 20 !
this means the treadmills power reading when the treadmill was operating at speeds of 1 miles per hour or less . Excessive amount of power is being demanded from the motor controller for an excessive period of time
Causes:treadmill user (especially a heavier user) is standing on the drive belt.
the drive belt too is badly worn.
brush motor faulty
SCR motor cotroller lekay or shorted drive motor or capacitor
IN short RUN the sotware calibration for diagnostic.
Remedies:Lube the deck belt, determine using AC ammeter for the amount of use the current being drawn by the readmill.Replace the drive motor brushes.or replce the motor controller board. see the block diagram
God bless you
Oct 11, 2012 | Tunturi T70 Treadmill
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
Supplier for a Tunturi T85 treadmill circuit board?
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
Sep 14, 2012 | Tunturi T85 Treadmill
ELEVATION RAISED AND STOPED
pleae RUN inmediately the software caibration for diagnose, troubleshooting, fix it.
LUBE the gear and shaft elevation motor, see the diagram
2) test the elevation motor, see the instruc.
God bless you
Jul 20, 2012 | Tunturi T60 Folding Treadmill
I have a tunturi t60 and it as stopped working and says data transfer error on display
Dear Sir:
LUBE inmediately the machine, the problem is lack of maintenance, maybe you have deck belt worn, that produce enough friction and by consequence shut down the machine.
2) Lube the rollers bearing in according with the instr.manual schedule.
3) Measure the voltage motor, if there are voltage the motor need repair or replace.
4) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
5) Run the software calibration for diagnose, and troubleshooting.
See my personal tips for help.
sincerely. God bless you.
May 07, 2012 | Tunturi T60 Folding Treadmill
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
Jun 18, 2010 | Tunturi T60 Folding Treadmill
Exercise & Fitness Logo
206 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
