Question about Eva-Dry EDV1100 Petite Mini-Dehumidifier Dehumidifier
Blinking green light? - Eva-Dry EDV1100 Petite Mini-Dehumidifier Dehumidifier
I e got a frigidaire energy star dehumidifier. Only the green power light cuts on. How can I get this appliance running?
Thank you for your inquiry, friend!
I see that you have a Frigidaire dehumidifier and the green power light stays on except it is not working. Typically, you have to set the dehumidifier in order to operate. What does your display say? If you can provide me with any additional information I would be happy to assist you. -Matt
May 06, 2015 | Frigidaire Dehumidifiers
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
Slow blinking light the same as johnworland on june 13th. A solid light indicates full bucket. I was getting full bucket light the last couple of times I checked the unit. odd because it is set up for...
remove the bucket and check the yop of it for a Float Valve. The float my be stuck in the UP position, If so, jiggle the arm of the float to make it return to the DOWN position.
Jul 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Danby DDR4007EE Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Dec 30, 2009 | Kenmore 54701 Dehumidifier
Newair ADS-300 Dehumidifier
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Dehumidifiers Logo
299 people viewed this question
Top Eva-Dry Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you an Eva-Dry Dehumidifier Expert? Answer questions, earn points and help others
