E725 reset bios
Bios not detect and laptop restarted again again
    Master:
  • 785 Answers
Go to repairshop and get a replacement of bios-chip, remember this is often costly todo, consider computer replacement and remove the harddrive from old one and put that in a external usb-cabinette.
Posted on Oct 17, 2013
Clearing cmos on e725
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
removing the cmos battery for 15 to 30 mins should reset your cmos
some motherboard cmos batteries are soldered in
failsafe or optimized defaults should do the job
hope this helps
Jun 30, 2012 | Acer For Emachines E720 E725 G420 G520 Ac...
How do you clear cmos on the e725
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jun 30, 2012 | Acer eMachines E7254520 Notebook PC
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
After pressing powerbutton startup stops with a black screen and text: schrijfleesfout
- this means "disk read error"
- you might have a faulty HDD
- try to restart the system and boot to bios by pressing F2
- check under system information if the HDD is detected
- if it's detected or not detected, try to reset Bios to default by pressing F9 and F10
- upon doing this and still the same error then call acer if the laptop is still under warranty to have them replace the HDD
Jul 13, 2011 | Acer Aspire 3610 Notebook
If I try to start my acer aspire 532 H netbook only : a disk read error occurred" and Press ctrl+alt+del to restart ist show, but nothing happens, when i did it. what can i do?
- a "disk read error occur pertains to your hard drive
- try going to BIOS and check if the HDD is detected on system information
- if the HDD is detected, reset BIOS to default
- if it's not detected then you have a faulty HDD
Jul 02, 2011 | Acer Aspire One 532h2298 Netbook
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
Operating system not found
1.Try restarting the computer in safe mode, keep tapping the F8 key as soon as you restart the computer and then from the advance boot options select the safe mode option to boot the computer to safe mode.
2. If the computer boots to safe mode perform a system restore.
3. If issue persists, reset the BIOS to defaults and then try again.
4. Verify if the hard is detected and listed in the BIOS setup. (press F2 at startup to enter BIOS).
5. If hard drive is detected and listed with its capacity such as 300/5oo GB, then, perform system recovery using the F10 recovery partition.
6. Restart the computer and start tapping the F10 key immediately to enter the system recovery partition, then, select the Rescue data option to backup the data from computer if any available or select the restore C drive option to perform system recovery and restore computer to factory settings.
You can also perform a memory diagnostics before performing the recovery.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1000582
If the hard drive is not listed in BIOS with its capacity, contact Sony service team to get the hard drive replaced.
If the computer is brand new, you can try exchanging the notebook with a new one.
Nov 09, 2010 | Sony VAIO Notebook
Pc "bios"problem
this looks like you have kept the bios password and you forgot it. just do one thing open the cpu case to access the inside of the system and then just remove the battery in it. wait for 5 min and again plug in the battery. thats it your bios memory password will be reset.
2nd solution without removing battery. just reset the bios as shorting the jumper pins. consult your motherboard book to know where to find the bios reset. it will be written as CLEAR CMOS.
Dec 21, 2009 | Intel Computers & Internet
Boots up but BIOS can't detected.
Try resetting your CMOS chip and restart. Wait for the PC to tell you that the setting have changed and press the corresponding key to enter the BIOS settings. Refer to your Motherboards manual as to how to navigate through the Bios settings and change the setting for your SATA connection to Automatic.
Jan 22, 2009 | ASUS P5LD2-VM Motherboard
Dvd-rw is not being detected by bios
try the following
1.reseat the odd..u can find the steps at the below mentioned link
http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1076794
2. reset the bios to defaults
3. remove the upper and lower filters
the registry path is
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
plz let me know if it helps so that we can check further possibilities and do rate the solution
Mar 18, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
