Question about Yamaha CRW 8424 Burner
Crw8424s scsi Hiya my cd rw is now working but showing one red light solid i can open it and that red light will turn green with disc in it.It will burn a few times the it will be totaly powerless only its like not enought power to open the draw and also two solid lights.When reboot pc it will just be one red light but wrk again dont know wots going on with it please help.
No you was right on target i think.thankyou so much if i got a different cdrw drive would it have to be a scsi one as the yamaha is scsi. many thanks zozzykid
Posted on Sep 27, 2007
    President:
  • 2,961 Answers
The drive is ready to give up, when it cant read dvds or cd's and unable to eject because it cannot read tracks and commands it's time to buy a new one, they are very cheap and easy to fit yourself.
Posted on Sep 26, 2007
SOURCE:
I am using a gto pro 2000 series automatic gate and the gate stopped opening. All fuses are good, green LED in the control box is solid and the red is solid. All connections look good. BAttery is charged....
The belt that drives the tray in and out is either broken or slipping. The belt is attached to a motor and as the motor spins the belt will rotate a pulley which drives the tray mechanism.
Nov 25, 2010 | FirewireDirect PRO Series (50.200) CD-RW...
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Problem with yamaha crw8424s...this device was working untill today...now the device has 2 flashing red lights, is no longer recognized, and drawer does not open or close. Any ideas or is this device shot...
Power off the PC, open the case, disconnect burner, power on pc, restart it, power off, reconnect burner, power on. If it work's then you're done. If no, ask your local computer story for a DVD burner
Nov 20, 2009 | Yamaha CRW 8424 Burner
Disc drive won't open and the busy light just keeps blinking green and yellow
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
do it with the pc turned off :)
Oct 21, 2009 | Plextor PlexWriter 48/24/48A CD-RW Burner
Can play cd's but not dvd's, just a rythmic wirring sound and green activity light
Hey,
just looking at the specifications, it should work with All CD's and Read Normal DVD discs, the movies that you can rent and buy from any store but it appears its a combo drive (Cd burner, and a DvD reader) It will only read DVD-rom and maybe few other things but it wont play any r or rw dvd's. It might also read already burned dvd r and rw discs but it wont read a empty one.
if it won't read any dvd's it could be a dirty lens. here's a video on the cleaning, its annoyingly loud but shows how to clean the lens with rubbing alcohol.
may want to turn the volume down in advance:
its for a ps2 but the drive is basically the same, and you would clean the lens in the same way.
let me know how that goes.
Thanks,
Ekse
Jun 03, 2009 | Dell Inspiron 6400 Notebook
Sharper image digital photo album
well - I figured out that you have to first wait until it's fully charged and the light changes from red to green. If you are still unsucessful, close the application. Then open the application (I mean the photo viewer that you've already installed from the disc) up again.
Oct 25, 2008 | Alera Technologies Digital Photo Copy...
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
My dvd burneer wont reconise dvd and dvd_rw discs
Check the blank disks in another computer if you can in case they are damaged and causing a fatal error when your computer tries to read them, and the reboot.
Are you sure it's SCSI and not SATA as scsi isn't very common these days especially on desktop type PC's? Where are you looking to see if the driver is correct?
If the drive is displaying and can be accessed from your operating system then it should be working fine.
Jan 04, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Cre8424s scsi
Your CDRW has broken and you will need to replace it.
Sep 01, 2007 | Yamaha CRW 8424 Burner
Open Questions:
SBCglobal MAil help {1^/855~/536~/5666-} desk NuMbER WASHINGTON Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
Oct 15, 2019 | VIA Computers & Internet
SBCglobal MAil CuStOMeR NuMbER {1=855={536}{5666}#[email protected] ALASKA Sbcglobal Technical Support Team Solve{1=855=536=5666}#O{1=855=536=5666}#[email protected] All Type Issues. We, at SBCglobal customer services, offering complete{1=855=536=5666}#[email protected] C solution that you{1=855=536=5666}#[email protected] NEW JERSEY have been looking for.{1^855^536^5666}#[email protected] ALABAMA We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity{1=855=536=5666}#[email protected] NEW MEXICO problems, Sbcglobal email password recovery, and complete{1=855=536=5666}#[email protected] TECH SUPPORT support related to your Sbcglobal email account. If Facing issues {1=855=536=5666}#[email protected] SUPPORT NUMBERin Sbcglobal email then Contact on Sbcglobal technical support phone number to fix the technical issues via expert technicians.Sbcglobal customer service excutive are well expert and help their customers 24x71^**********^ PROBLEMbcglobal Technical Support Team Solve All Type Issues. We, at SBCglobal customer services, offering complete solution that you have been looking for. We serve the better satisfaction with cent percent. Our Sbcglobal email instant technical support includes dealing with connectivity problems, Sbcglobal{1=855=536=5666}#[email protected] MINNESOTAemail password recovery, and complete support related to your Sbcglobal email account
See all Yamaha CRW 8424 Burner Questions
Yamaha CRW 8424 Burner Logo
501 people viewed this question
Top Yamaha Computers & Internet Experts
Ekse
Marvin
Marvin
yobo007
yobo007
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
