Question about Raytec 6" Aluminum Heavy Duty Hang Fast Hidden Spouting Gutter Hanger 10
1 of the hangers has come off due to large quantity of snow sliding off metal roof. The installer wont come back to fix due to 'snow damage'. How do I re-install the hanger?
  • 3 Answers
First you need a ladder with a stabilizer bar. Once you're up there you will see that most likely they clip on to the outer part of the inside of the gutter.push down the hanger until the other end it's against the fascia you then will need to drill a screw through a hole in the hangar that will be against the fascia board.you will need a drill with an extension depending of what type of screw is being used.be careful as it is very slipperyand dangerous to go on ladders when there snow.you might also want to run down to a hardware store and ad additional hangers. If they come in a pack they will most likely have instructions or they can help you in the hardware store try Home Depot
Posted on Jan 07, 2015
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Keystone hornet rv
Find another dealer...those guys are f***tards! That slide should be level and even when in OR out. Bent slide mechanism, mal-adjusted runners maybe. Have it checked out by someone who knows what they are doing.
Water can leak in FAR from where you see the damage. It runs downhill finding a low spot to settle. I would re-caulk the whole RV, paying special attention to the roof. Spend the money on roof sealer if you have to. Silicone tube caulk is a temporary fix. To be done right, you disassemble joints/panels and use the ribbon/string caulk. More work but should last at least 5 years.
Sooner or later they ALL will spring a leak. Keeping up on inspection and re-sealing regularly will minimize the damage.
Aug 21, 2014 | Keystone 2011 Hornet 30RKDS
How to install slate roofing
A slate roofing is actually a nice idea because its make your home quite pretty. To use slate roofing first you need better kins of slates its breakable also but now including roofing you should try another options like metal roofing, rolled roofing , its easy then slate roofing you can also visit http://andersonindustrialroofing.net/replacement/
Jan 12, 2013 | Roofing
How do i get the leaves off of my steep metal roof
Buy a snow roof rake.They have poly propolene radial scoops on them they wont dammage roof. You can use it for snow as well. You wont need the latter. Mutch lighter as well.
Nov 28, 2012 | Cars & Trucks
2007 camry water leaking drivers side
If you have had a winshield installed it could be the seal around it. If not the it sounds like your A/C drains could be blocked . You will need to take it to a repair shop and have the drains blown out. If you have a Sun roof it also could be the drain are plugged . You can clean these your self .. just open the sun roof all the up and at the corners all the way in the front of the slides for the roof panel are drain hole clean them out till you can see where the holes go out and use a piece of wire ( metal coat hanger) only push it in 2 or 3 inch's to far and you can damage the rubber tube or put a hole in it .
Aug 05, 2012 | 2007 Toyota Camry
My sunroof is not able to be closed. It is in the pop up position. Is there a manual way to close it? eg no use of electricity?
there is no manual method. It sounds like a limit switch is not working. Can you hear the motor try to operate? If you push up on the back of the glass a little bit while hitting the switch, what happens.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
The sliding roof panel system consists of the following components:
  • RH circuit breaker
  • Timer module
  • Power window relay
  • Roof sliding panel switch (15B691)
  • Roof glass panel (50054)
  • Sliding roof panel motor (15790)
  • Halo moulding
  • Roof sliding panel headlining (519A02)
  • Roof sliding panel slide links (502M78)
  • Roof sliding panel housing (502C22)
  • Roof air deflector (500A26)
  • Center green diode strip
When the roof sliding panel switch is activated, a gear on the sliding roof panel motor drives a spline on the roof sliding panel housing. Within the roof sliding panel housing, the spline is connected to two sliding roof panel cables which cause the roof sliding panel slide links to slide and the roof glass panel to open or to close. The sliding roof panel cables and the spline are part of the roof sliding panel housing. Neither the sliding roof panel motor nor the roof sliding panel housing can be disassembled. If a malfunction is detected with either of these assemblies, the assembly must be replaced.
VISUAL INSPECTION CHART Mechanical Electrical
  • Sliding roof panel height adjustment
  • Sliding roof panel fore and aft adjustment
  • Blown fuse(s):
    • 30A PWR WDW
  • Damaged circuit breaker #1
  • Damaged wiring harness
  • Loose or corroded connections
  • Fuses.
  • Circuit breaker #2.
  • Power window relay.
  • Sliding roof panel motor.
  • Roof sliding panel switch.
  • Circuit.
  • GO to Pinpoint Test E1 .
  • Sliding Roof Panel Will Not Stop in Vent Position
Switch Removal
  1. Disconnect the battery ground cable (14301).
  1. Gently pry the overhead console from the headliner.
  1. Disconnect the sliding roof panel electrical connector from the overhead console.
  1. Disconnect the rear quarter window switch electrical connector from the overhead console, if equipped.
  1. Disconnect the map lamp electrical connector from the overhead console.
  1. Remove the overhead console.
  1. Remove the two roof sliding panel switch screws and the roof sliding panel switch (15B691).
Motor Removal
  1. Place the roof glass panel (50054) in the closed position.
  1. Remove the roof headlining (51916). Refer to Section 01-05 for the removal procedure.
  1. Remove the two sliding roof panel relays from their brackets.
  1. Disconnect the two sliding roof panel motor electrical connectors.
  1. Remove the two sliding roof panel motor screws and the sliding roof panel motor (15790
Jan 11, 2010 | 1997 Mercury Villager
Sunroofs off track and wont close
If your indicating the roof is crooked, that's odd... The roof slides along a channel actuated by a coiled cord.
Both of the cords pass along a gear attached to the Sunroof motor which pulles the cord tooth by tooth, impossible to go crooked unless really jammed or tampered with.
There are two plastic wedges that drop into the plastic slides on the sunroof (the plastic slides are behind the more forward metal slides.)
The plastic slides control the tilt of the roof when moved independantly. The plastic wedges join them.
If the roof moves too far back, it is possible for the wedges to stick up and jam the roof open.
This should never happen, but could if the two switches on the gear fail and no longer provide feedback to the controller indicating the roofs position.
Access to the Sunroof motor requires you to drop the headliner.
To drop the headliner, the plastic pillar shrouds need to be removed front and back, the seatbelt bolts in the middle secion need to be removed, the oh-**** handle, the front visors, and cabin lights.
Hope the info is helpful.
Jun 08, 2009 | 1997 Pontiac Grand Prix
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Open power feed fuse.
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Raytec 6" Aluminum Heavy Duty Hang Fast Hidden Spouting Gutter Hanger 10 Logo
914 people viewed this question
Top Raytec Roofing Experts
Colin Stickland
Colin Stickland
Mike
Are you a Raytec Roofing Expert? Answer questions, earn points and help others
