Question about Panasonic Microwave Ovens
The MICROWAVE STOPS BEFORE THE TIME SET - Panasonic Microwave Ovens
  • Panasonic Master
  • 9,047 Answers
<p><font face="arial,helvetica,sans-serif"><span style="font-family: Arial;"><b>
Diagnosing Panasonic microwave oven stoppages:</b><br>
<br>
If it stops after 22 seconds, that means the controller has detected a problem,
usually a problem with the inverter, controller,&nbsp;magnetron, or a bad connection
from one or the other.</span></font><br>
<font face="arial,helvetica,sans-serif"><span style="font-family: Arial;"><br>
If it stops at 16 seconds and is a sensor model, it probably has a defective
humidity sensor.<br>
<br>
If it stops after 7 seconds, it has a problem with the&nbsp;inverter.</span></font><br>
If the digital programmer circuit / controller does not get a feedback signal
from the inverter for a period of 3 seconds, the controller will stop the cook
cycle.<br>
<br>
Or see if this describes what's happening:<br>
<br>
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes
off. Cook time on display goes off and clock time comes back. Bad upper
interlock switch and charred connector. If so, see:<br>
<br>
<a rel='nofollow' href="http://031d26d.namesecurehost.com/mwd/safety.txt">
http://031d26d.namesecurehost.com/mwd/safety.txt</a></span></font></p>
<a rel='nofollow' href="http://031d26d.namesecurehost.com/mwd/disassembly.txt">
http://031d26d.namesecurehost.com/mwd/disassembly.txt</a></span></font></p>
<a rel='nofollow' href="http://031d26d.namesecurehost.com/mwd/doorsw.txt">
http://031d26d.namesecurehost.com/mwd/doorsw.txt</a><br>
<br>
It may be a loose connection in the wiring between the inverter,&nbsp;magnetron,
and/or control board, or maybe one of those components has failed.</span><br style="font-family: Arial;">
<font face="Arial"><br>
</font><span style="font-family: Arial;">Due to the complexity and lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.</span><br style="font-family: Arial;">
<span style="font-family: Arial;">You can </span>
<a style="font-family: Arial;" target="_blank" rel='nofollow' href="http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1">
find an authorized Panasonic servicer here</a><span style="font-family: Arial;">.</span><br style="font-family: Arial;">
</font><span style="font-family: Arial;">In Canada, you can </span>
<a style="font-family: Arial;" target="_blank" rel='nofollow' href="http://panasonic.ca/english/customercare/servicentrelocator/default.asp">
find an authorized Panasonic servicer here</a><span style="font-family: Arial;">.</span><font face="Arial"><br>
&nbsp;</font></font></p>
Posted on Oct 17, 2013
  • GIUSEPPE MARTIN Oct 18, 2013
    Good morning, Thanks for the reply, I am aware of the danger but I have experience in electronics, I checked the inverter board, power supply, and I found a diode UX-C2B in short, I replaced it I tried again to run the microwave and it is broken again, quancosa is definitely in short, I checked the condensers of power but I am ok, I also checked the power mosfet inverter with special tool but even these are ok I guess is because of the magnetron is broken or short but I do not know how to measure. The cause of the non-operation of the microwave think it was a layer of dust which closed the ventilation area thus bringing high temperatures within the oven. Do you think it could be the magnetron? you know how I can understand if the cause is his?
I have a Panasonic Microwave the Genius Prestige and when I set the time to cook it turns off in 9 seconds even though I set it for 50 seconds. what should I do?
You have a defective timer circuit board, which I assume is part of the main board of the microwave. If the unit is older just replace it, if it is relatively new call a Panasonic repair service and get an estimate to repair it, I think you will be shocked by the cost to repair.
Jul 18, 2016 | Panasonic Microwave Ovens
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
The microwave stops after a few seconds. It starts, but stops before the set time is completed. The oven is five years old.
Does the oven's key pad seem to reset like a breaker flipped inside? And after, you have to reset the clock? If so, check the temperature cutoff switches inside. Jumper across them and see if your microwave starts working correctly. I had this problem and the Bottom TCO was defective.
Feb 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Stops after 3 seconds - Panasonic NN-S252BF
may be magnetron spoiled or high voltage section problem,please check circuit andreplace damage parts...
Aug 14, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
262 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
