Question about Hampton Bay 24002 Ceiling Fan
How to fix a noisy ceiling fan - Hampton Bay 24002 Ceiling Fan
  • 25 Answers
Try tightening the screw part that holds the light cover on!!!!!
Posted on Oct 17, 2013
  • Jeff Strout
    Jeff Strout Oct 17, 2013
    What kind of sound is it making??
How can I fix a noisy fan
That"s a low end store brand. You get what you pay for. Next time buy a fan at a fan store not a store that sales fans.
Sep 07, 2014 | Hampton Bay 24002 Ceiling Fan
Where is the model number of a flush mount ceiling fan?
Where can I locate the model number of the fan?
There's a gold sticker on top of your fan's motor (the part that faces the ceiling once it is installed). Holding a mirror above the fan motor can help you read the numbers. It may also be found on the parts guide that was packed with your fan or on the box that contained your fan. You're looking for a 5-digit number and it sometimes has a suffix...i.e. 22345A
Aug 14, 2014 | Hunter Dryers
Manual for aHAMPTON BAY ceiling fan campbell
Fan is a little noisy on med or full speed, is there a place to oil it? The fan is level & doesn't wobble.
Apr 02, 2013 | Hampton Bay Dryers
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
The fan is making a "scratching" noise.
Hi steffmarin...
The scratching noise is one of two problems.
1.noisy fan bearings, cannot be lubricated, must be replaced (big job), or replace fan....
2. Plastic/rubber bearing up near the ceiling...the fan will be connected to it.
Sometimes when they get dry they get noisy.
You can spray the plastic/rubber bearing with a little WD-40 and it will hold the noise quite for a while...be sure to "wiggle" the fan around after spraying to distribute the WD-40) evenly.
If your noise problem is this then problem solved.
Please take time to rate me
Jul 22, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
Fan is wobbling and noisy--cannot figure how to tighten the light fixture part of fan
I have a number of ceiling fans and its usally wise to just check that each blade as all the washes and fixing. As leaving just a washer out can alter the whight and balance.Some noise is to be exspected till they bed in so to speak unless they wobble really bad
Sep 29, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling fan is controlled by dimmer
Yes, if the hot wire going up to the fan is coming off the dimmer, it is reduced voltage and will slow down. There maybe a separate hot from another switch??
Jul 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Altura 68" ceiling fan noisy
TAKE THE DARN THING BACK, IT SHOULD NOT MAKE ANY NOISE.
Jan 13, 2009 | Hampton Bay 24002 Ceiling Fan
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
