Question about Garmin Watches
The "OK" button does not respond on my Garmin Approach S 1 watch. The watch will turn on to give me the time, but when I press the "OK" button on the tee, there is no response. Bad connection internally??
Wrong time, how to correct?
Go here: https://support.garmin.com/support/sw/supportPage/display?locale=en_US&topicIDs=%7B6d19e750-030b-11dc-e9ab-000000000000%7D&topicIDs=Golfing&topicIDs=%7B264ef550-dc0c-11dd-5c1e-000000000000%7D&topicIDs={008a0ef0-7e65-11e1-6a4c-000000000000}
Jul 02, 2015 | Garmin Approach S3 in White 010-01049-00
How do I change from military time to civilian time?
After 12 noon take 12 hours off of Military time for hours in the pm
8 is 8am the 14 hours is 2pm
May 23, 2015 | Garmin Approach S1 Golf GPS Watch
Can't locate sattelites on golf course
When you try to locate satellites it could take some minutes before the device find enough to calculate the location. Please give it some time. Also make sure the watch is charged.
Mar 16, 2015 | Garmin Approach S1 Wrist Watch green
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Can I buy a menu button?Menu
Parts are not on the market, contact the manufacturer for parts or
Jun 29, 2014 | Garmin Approach S1 Golf GPS Watch
Tag Heuer Chronograph Problem
These are a top brand and any dealer should be willing to give you advice for free, drop in to a jeweller that sells them, and ask.
Dec 15, 2013 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 16, 2011 | Polar S S625X Wrist Watch
How do i change the time on my polar f6 watch
5.1.3 TIME SETTING
If you start from the Time of Day display, repeat steps 1-3, page 38.
4. Press the / buttons to select TIME. Press OK.
5. Press the / buttons to select 12 H or 24 H time mode. Press OK.
If you chose 12 h mode, select AM or PM with the / buttons. Press OK.
6. Set the hours with the / buttons. Press OK.
7. Set the minutes with the / buttons. Press OK.
Nov 25, 2009 | Polar F6 Wrist Watch
I can't turn the chime off my Garmin50
press and hold the view button on time screen. The chime icon will flash, after few seconds it disappear
Apr 10, 2009 | Garmin Forerunner 50
Watches Logo
20 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
