Question about EnGenius Computers & Internet
Cant change router password
I have recently had to change my broadband connection on my computer and I can't figure out how to set it up with my EnGenius router.
    Master:
  • 368 Answers
Ok you have another option you can reset your router .
Posted on Jan 29, 2015
    Genius:
  • 1,061 Answers
If your on windows from a command line type ipconfig /release and reboot..not sure how to call 225-290-5733
Posted on May 24, 2014
4 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: PRINTER CONNECTION
What is your printer?
Posted on Jul 26, 2008
interact07
  • 4 Answers
SOURCE: fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Posted on Jan 24, 2009
Macs R We
  • 481 Answers
SOURCE: cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
Posted on Oct 28, 2009
I have a WT54g Linksys Wireless G Broadband router. I have a LAN on which I have 4 computers. Recently my HP printer had problems and the technician set it up as a wireless. I've had some problems with...
You may be able to view th eexisting SSID and key by loggin into the router's web interface. You can do that by entering the IP address of the router into the address bar of your web browser of choice (it's usally http://192.168.0.1 or http://192.168.1.1) If it asks for a login, it's usually "admin" and "admin" for the username and password. From there you can look for the wireless settings and get the SSID and password that way (or if it doesn't display the password, you can at least change it to something you do know.)
Mar 01, 2011 | Cisco Linksys WirelessG Broadband Router...
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I can't figure out my security settings. I currently have it set to: Authentication: Open Encryption: WEP-128 and Key input to phass phrase: for which I selected a common password that I use My...
WEP usually gives you a passkey, you do not choose this.
If you choose WPA2, then you can choose a password.
WPA2 is far more secure, and if you have the option to choose it, then do so.
Log on to your router and check if it is available
Oct 22, 2010 | Arris Wireless G Broadband Router (wr850g)
I tried to set up a password with my wireless 2350 broadband router and now its saying that the settings don't match my network.. i need help
Change your wireless settings on your computer. Use the router's password. that way you will be able to gain access to your router. when you changed the settings on your router it does not automatically update your computer's connection settings. you have to manually change it. try right clicking the icon for your wireless on your computer. go to the connection settings and add a password that corresponds to the settings you changed on your router.
Mar 11, 2010 | Dell Wireless 2350 Router
Cant connect wirelessly to my router. have done all the steps like WEP setup, password and router name. just says failed when i try to connect wirelessly. and when i try to connect the router to my comp...
You will need to check the settings of the router. You said that if you connect the cable to the router and computer, it still doesn't work.
First make sure that the computer is able to go online when connected to the modem directly, without the router. If your computer is able to go online through the modem then your modem is working properly.
Now connect the modem and the computer to the router. check the IP address on the computer. open the set up page of the router. This is the page where you can change all the settings of the router. According to the type of Internet service change the settings of the router.
Click here for more information about the router and networking
Feb 14, 2010 | Linksys Wireless-G Broadband Router
I recently bought a linksys wireless router i've
Make sure your wireless feature is turned on on the computer. There may be a switch on the edge of the computer somewhere, you don't say what kind of computer it is.
Find the wireless connection wizard on your computer and run it. Find it in your network folder in the control panel.
If this is too much, post a comment to this question and we will back up and start over.
BTW, if your laptop has a ethernet outlet (looks like a big phone jack), you can wire your laptop to your router.
I want to help you with this problem
thanks
Dec 08, 2009 | Linksys Wireless-G Broadband Router
I recently got wireless internet from a Zonet router and i cant connect to my XBOX live account because it states that i dont have a sufficient MTU setting of 1364 which i need to connect to XBOX live
Go to your router, you can do that by simple going to a browser and then put your gateway in it. You will be asked for a password, after that you can now change the MTU setting in your router.
May 02, 2009 | Zonet ZSR3104WE 802.11G MIMO WIRELESS...
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
MTNL INTERNET PROBLEM
Hello.
Since your ISP provided you a username and password when connecting to a broadband connection, you have to setup the router's "Internet Connection Type" to PPPoE then you need to enter the username and password that you are using to connect to your broadband.
Once you do that, the router will obtain an IP address from your ISP(MTNL) then it will give connections to your computers
Aug 01, 2008 | Computers & Internet
I cant figure out my password
You can reset the router, There is a reset button when you press and hold it will change the settings to factory default, so you can use default password.
Good Luck
Jun 20, 2008 | Arris Wireless G Broadband Router (wr850g)
Computers & Internet Logo
130 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
