PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Repetitive beeping sound on startup - no ...
By dwfranks on Apr 25, 2009
I have an hp pavilion a420n. I powered it down, removed the power cord. and inserted a 512 mb ram chip. I tried starting it back up and the power button lights up and you can hear the fans, but the screen and keyboard don't respond. There is also a repeating beep sound that does not stop 5-6 second intervals. Is the power supply toast. How can I fix it?
Comments:
Apr 25, 2009
- The beeps are the same 2 second long beep 6-8 seconds apart - and I stopped/unplugged the pc after 20...
Apr 25, 2009
- I removed the chip and the beep is still present and no boot happening...
Apr 25, 2009
- The memory chip is an Edge 512 mb - 40 bar code 60136032418
The description says PC2700 NONECC UNBUFFERED 184 PIN DDR DIMM
I got this from Computer Memory Outlet that guides to the exact memory chip for this PC.
Like is referenced, this new one is not in the PC and I have the one 512mb I started with and still can't boot...
Thanks Macjax for any thoughts...
Apr 25, 2009
- Thanks for the help - I will continue to reseat the memory and see if it wakes up...I have reseated it several times (the original) and still no go...dw
Clarification Request
Posted by macjax on Apr 25, 2009
OK. Please tell me all information that in on the memory stick you install. All numbers on the stick.
Please give exact beep count a length. Example would be 1 long beep and 2 short beeps...
Solution #1
posted on Apr 25, 2009
Not Helpful)
chris612
Rank: Master
Rating: 80%, 8 votes
Remove the memory chip. It was probably either not installed properly or is not compatible with your PC. That should fix your problem.
Was this helpful?
Yes
No
Solution #2
posted on May 14, 2009
Not Rated)
yohandole
Rank: Apprentice
Rating: 0%, 0 votes
check this link for beep problems
http://en.kioskea.net/contents/pc/bios.php3
Was this helpful?
Yes
No
Solution #3
Not Rated)
macjax
Rank: Guru
Rating: 90%, 74 votes
Make sure you have it inserted correctly. Make sure it is pushed down all the way. You are using the correct memory for your laptop. If your original memory was working and now it isn't, then most likely you do not have it installed properly.
Was this helpful?
Yes
No
Solution #4
Not Rated)
kwgwg
Rank: Apprentice
Rating: 100%, 1 votes
try inserting the new memory better, lose memory cause this beping prob, it also happens in the video cards, ^^
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
What is the best NAS for about $300 (+, - $100)? I was looking at... (More)
Answer
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send Machinery until you... (More)
Answer
when i turn the computer on it has the black dell screen it starts to boot but when it gets 3/4 of... (More)
Answer
can i use asus-m2npv-vm without graphics card (problem my graphics card ) so i want do vga for this... (More)
Describe your PC Desktops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in Augusta, ME
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
