Question about I30 Latch & actuator assembly - front door right right hand
Repair hyundai door looks - I30 Latch & actuator assembly - front door right right hand
  • Hyundai Master
  • 17,970 Answers
Send us additional details.
Posted on Oct 17, 2013
Fuel door button and truck lock not working on 2010 hyundai xg350
With both of them not working I would look in owners manual and see what fuse controls them and check fuse. If the fuses r good get a repair manual and check the system
May 14, 2018 | Hyundai Cars & Trucks
My 2007 Hyundai Sonata has begun to lock the doors by itself.
Check debris in the key fob. Over time, dust and dirt may be causing the circuitry to track/short out and implement odd functions.
Aug 20, 2016 | Hyundai Cars & Trucks
Repair door lock actuator 2006 hyundai sonata
Hyundai Sonata 2006 Recall ID # 09V122000-Service brakes, hydraulic:switches:brake light., Recall ID # 08V161000 - air bags(more?)--------------------------------------------------------------------------------------
Launch X431 Master English Version
Mar 12, 2013 | 2006 Hyundai Sonata
Hyundai elentra bent frame and door handle
No way to tell without looking at it and taking measurements.
It may be cheaper to replace the doors than to spend the time on repairs.
Sep 05, 2012 | 2010 Hyundai Elantra
I have got a Hyundai Santa Fe 2011 with Smart Key Entry. it only works on the Cargo Door, but not on both Front Doors. Thanks a lot!
I believe this system on your vehicle is still under warranty. Call your nearest Hyundai Dealership's Service Department & look into it. There's a very good chance you can get this problem diagnosed and repaired under warranty.
Sep 05, 2011 | 2010 Hyundai Santa Fe
My hyundai sonata 2004 rear door has broke, can i change door with hyundai sonata 1998.
The 2004 door is not compatible with the 1998. You need to find a door in the 2002-2005 range. The 1998 door might look the same, but the mouldings, wiring (if you have a power door), and the trim card will be different. If you find one in the above year range you will be able just to put it on and drive away. If you decide to look for a used door call your dealer with your VIN Number and ask them for the paint code. If you are lucky you will be able to find a used door in color.
Good Luck!
Dec 15, 2009 | 2001 Hyundai Sonata
2004 Hyundai Accent door locks
Since the 3 other doors respond to your keyless remote, this points to a failure in the door's power lock motor.
Repairing this yourself can be done, given that you are able to access the part itself, and can diagnose servo/motor failures.
You must take great care in removing the door panelling. This is often attached to the metal frame via plastic pegs that can break when removed forcefully. You can ease them out with the help of a flat(blade) screwdriver. Start from the part with the smallest sq.area and work your way down.
Hyundai often places plastic caps to cover screw heads, so look for these to completely remove the door panel.
If you find this too tedious to accomplish, it is best seek assistance of a qualified technician.
Hope this helps.
Jun 28, 2009 | Hyundai Motor 2004 Accent
I30 Latch & actuator assembly - front door right right hand Logo
107 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
