Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Replaced Converge Chips on JVC AV56WP74 but need help
I replaced the Converge Chips on my JVC AV56wp74 and it works great but it looks like the picture is tilted lower on the left than right i havent found a way to adjust the tilt on this is there another way
Where can i get the service literature for the service menu?
Posted on Nov 12, 2007
    Genius:
  • 1,694 Answers
Service literature needed for servicer menu.
Posted on Sep 26, 2007
OK so my jvc av56wp74 will turn on with a green pic then turns off and the blue light in front blinks
it sounds like u need a new lamp with housing if that dont work than its your main board on the inside of tv. but i would try the lamp first
Aug 26, 2013 | JVC AV-56WP74 56" Rear Projection...
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
I NEED TO REPLACE THE LAMP. HOW DO I GET TO IT
The AV56WP74 has three CRTs instead of a lamp. You can get parts from www.tvrepairworld.com
Apr 02, 2010 | JVC AV-56WP74 56" Rear Projection...
My JVC model #AV56WP74 color is off. we tried adujusting the nobs but the blue doesnt seem to be working. What can I do?
Install the AV48WP74 convergence repair kit from www.tvrepairworld.com the kit contains the parts and the Cd with detailed instructions for the repair.
Jan 22, 2010 | JVC AV-56WP74 56" Rear Projection...
My screen is blank and the power button keeps flashing blue
AV56wp74? The power button blinking blue means the set is in shutdown----the most common reason for this in this set is one of the two convergence chips is shorted. The way I usually prove this is to remove rear cover and or front grill and examine convergence circuit located at the front of the set----Also--I will unplug the plug from that circuit board that goes to the TV's power supply---if the set turns on with the convergence circuit board unplugged from it---you know your trouble is one of the two chips---if this is the case both have to be replaced and the set adjusted.
I do this here for free so if this has helped you give me a vote here. If you have questions or need help let me know.
Aug 27, 2009 | JVC AV-56WP74 56" Rear Projection...
Red lines all over the screen
this set(AV56wp74) was first made in 2003----if you use the remote for the set and go into the customer menu---select convergence----once there see if the red and blue will move left/right and up/down----if either color will not move in any one of these directions----you have a bad convergence IC--this set uses 2 of the STK-392-110 output ic chips---both need to be replaced and the set adjusted with the original JVC remote control. I hope this has been helpful.
Aug 11, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC av56wp74 red lines won't converge. How can I fix it myself. I have seen that a few people have done it themselves, wondering if I can get some info on how much parts cost and if It is the chip is the...
1. disassemble front speaker panel.
2. locate circuit board in front with the 2 large black or silver heat sinks standing up. (this is your convergence board).
3. disconnect all the wires on this small board, but make sure you take a picture first to know where they all go.
4. look for 2 black cips that says stk ***-***.
5. order replacement chips on line.
6. learn to solder before chips get to you home.
7. watch you tube videos titled "how to fix tv convergence.
8. wa, la send me some money to show me your appreciation, lol.
Jun 04, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC av56wp74 IC CHIP
you can get the replacement STK392-110 Ics and the JVC convergence resistor kit #1 at the following link which has the complete step by step instructions with pictures so you can easially do it yourself. You will need the resistors also as JVC will definately blow one or two resistors minimum when the Ics fail. Heres the link.
http://servicemanuals.vstore.ca/
Feb 01, 2009 | Televison & Video
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Converge problem how to fix JVC AV56wp74
There are two of the IC's in the tv. First things first, turn the tv off and unplug it. Wait a few minutes, then open up the back by unscrewing the screws in the back panel. Now slide out the wooden panel that divides the upper and lower part of the cabinet. You'll see some cards sticking out of the plastic input panel. Find the one for DVI (it's the furthest to the right and it's at the top). Unplug all of the cables that are attached to this board. If you look closely, on the top of this board (the edge facing the top of the tv) there is a tiny little square looking hole on it. Cover this with black electrical tape or something that will not allow light in. The reason we do this is because JVC made a booby trap that erases the eeprom if you try and operate the tv with the back off. If the sensor senses light when the tv is on, it will erase the eeprom. Ok well now that that's covered, the actual convergence board (the one with the two IC's) is the board in the very front of the tv. It's long and slim and you'll immediately be able to see the two IC chips. They are big black things with lots of pins and they are pushed up against heatsinks. Those are what you would want to replace. Now I've not taken the boards out before, but from the looks of things, all of the boards are on a big black plastic tray so you can take them all out at once. I don't know if you can get just the convergence board out very easily, but at least now you know where and what it is. I would seek further instruction from someone a bit more knowledgeable about taking the boards out, but that should give you enough to do until you find more help. Hope this helped!
Jul 31, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
