Question about Dishwashers
Not drying is not drying
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
No heat? test element and circuit from control board.
If Dishlex DX103 etc, resolder relay onto board and get quote on new control board.
Posted on Oct 18, 2013
I have a 1992 jeep Cherokee Laredo 4.0 L6. How do I fix dry starting?
dry, i love new terms for problems my first like this.
  1. dry road.
  2. no beer in hand.
  3. fuel tank dry (buy some, LOL)
  4. coolant dry starts. (testing new engines....)
or what, do add a noun to the dry work,
what is dry?
and what fluid ends the dry.?
Nov 04, 2015 | Jeep Cars & Trucks
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
What freeze dried fruits are available?
You can buy plenty of different freeze dried fruits: bananas, apples, apricots, strawberries, blueberries, dried mango, pineapple, raspberry, and more. You can buy freeze dried fruit on this website: http://store.honeyvillegrain.com/freeze-dried-fruits.aspx.
Aug 12, 2012 | Camping, Backpacking & Hiking
What is freeze dried coffee?
Freeze dried coffee is liquid coffee that's been dehydrated. Once put in hot water, it can be drank again.
Reset kenmore dishwasher
The most common "reset" key sequences are:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry).
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jun 15, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Aug 12, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
