Question about Olivetti Office Equipment & Supplies
It works just fine until it reaches the middle of the paper. Then it stops moving so all the letters end up on top of each other. The space bar also doesn't work after it reaches mid way on the paper - even though it works perfectly fine before that point.
    Champion:
  • 204 Answers
The right margin is set..reset the margin, or there is a bind in the carriage. Use the MR (margin release key). to get by the margin, then reset it.
Posted on Oct 17, 2013
  • 3594 Answers
SOURCE: IBM Wheelwriter 10 Series II Typewriter
There is a plastic cap on the end of the print solenoid plunger whichis probably broken. They are available fron us for 15.00 including postage but can be a little tricky to install
DickyO
Posted on Dec 09, 2008
  • 3594 Answers
SOURCE: On the IBM selectric 2 - the keys are locked up -
Try the shift key, then try pressing each key on the key board one may be partially tripped.
DickyO
Posted on May 07, 2009
  • 3594 Answers
SOURCE: space bar key doesn't work
If the keys do nothing at all you probably need a keyboard, if they do something but not what you want try a little WD40 on the silver shaft that guides the carrier. If it's the KB contact Geo. Beyers Co.
1-800-392-8085
Posted on Aug 21, 2009
  • 3594 Answers
SOURCE: Here's the problem: it types just fine, but only
Take out the printwheel, manually turn it look for bent or broken spokes on it, or just breplace it.
DickyO
Posted on Oct 30, 2009
squipps
  • 204 Answers
SOURCE: I have an old school
If there is tension on the carriage when you push it to the right, the spring is not broke or the cord..then the problem would be in the escapement area..you would need a repairman to do this. if the carriage is loose, no tension then the spring is either broke or the cord is off or broke.
Either way not something easy....
Posted on Dec 19, 2009
Space bar will not work.
It's probably just dirty and gunked up. Clean it with Q-tips and a bit of rubbing alcohol.
Nov 19, 2014 | Xerox Memorywriter 60 Series - Correctable...
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
I am trying to print a document in Word and my Phaser 8560 will print it, but there is a blank section on the page (approximately 4 inches wide running down the middle of the page) where the text did not...
Did the document print in full even though it left blank spaces? I f so the problem is The Page Break Occurred before it actually reached the end of the paper. Check what paper is selected on the printer. I don't mean the tray or paper feeder.
On the LCD screen on the printer go through the menu till you find the paper. Make sure the paper is set to A4 or Letter (whatever you normally use.) and make sure this setting matches with the paper select in the documenent.
Check File ->Print ->Settings or Options .... Find out where the paper is mentioned and select A4 or Letter as the case may be.
Hope this will solve your problem
Good luck
luciana44
Jan 06, 2010 | Xerox Phaser 8560N Laser Printer
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
Lexmark x4690 scanner jam
Perform a hardware test, instructions on how to do so at http://support.lexmark.com , find your printer model, and then click the how to's tab.
If no solution is found or you cannot print the page call 1-800-332-4120
Mon - Fri: 8 am - 11 pm & Sat: 10 am - 7 pm for lexmark technical support.
Apr 24, 2009 | Dell 924 All-in-One InkJet Printer
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
CHAMPION PAPER SHREDDER
My champion shredder had too many papers go thru because I didn't see the enclosure in one of the flyers. the shredder has now stopped. I have tried to pull the paper out but I reverse the wheel and now the paper is stuck behind the the wheel where I can reach. The motor is now ona humming sound. Are there screws on either end that I can remove the top? Please give advise n what to do. This is not and old shredder.
Oct 20, 2008 | Office Equipment & Supplies
MY PRINTER SAYS 34 SHORT PAPER HOW DO I FIX IT
open paper tray and look at the paper stopper ( the one on the end that you can adjust for the paper lenght)
is it set for letter?
now take a look on the SIDE of the tray there are three prongs, when you adjust the paper lenght, are they moving as you adjust the paper? for letter size the bottom two should be out and the top one should be in.
Nov 14, 2007 | Lexmark T522 Laser Printer
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
