Question about Sony Vtg 80s Cfs-500 Stereo Boombox Ghettoblaster Am Fm Radio Tape Player Japan
Taking it apart!! - Sony Vtg 80s Cfs-500 Stereo Boombox Ghettoblaster Am Fm Radio Tape Player Japan
  • dino borza
    dino borza Oct 17, 2013
    taking radio apart
Take apart cuisinart sco-60
there are screws on the bottum, and snap locks that make it tricky to take apart, you almost have to break it to get it apart.
Nov 26, 2014 | Cuisinart Coffee Makers & Espresso...
Tip
How to take apart your Whirlpool made washer
This tip applies to Whirlpool brand washers which include,Whirlpool,Kenmore,KitchenAid,Estate,Roper,Inglas,Kirkland(costco) Ikea, someMaytag,Crosley,Jennair and others made by Whirlpool<br /><br />It gets sorta confusing how to take apart these brand washers,they come apart totally different than you may think. This YOUTUBE video will show you how to take them apart<utube src="Puq8jWMY9Iw&feature=player_embedded">
on Sep 05, 2011 | Washing Machines
Brother take apart
Hello
Before you take the machine apart, check that the bobbin winder is not engaged and that the fly wheel is locked in place. Both can be done without taking the machine apart.
Happy Stitching.
Aug 06, 2014 | Brother LS-1520 Mechanical Sewing Machine
Take it apart
I had the same issue. What I found upon taking it apart was that it must have fallen and the case was not making contact with one of the safety switches. Taking it apart was easy a mix of phillips head screws and torx screws. Took me 15 minutes to take apart and find the bad spot. I hope your fix is this easy.
Jul 07, 2014 | Oreck XL Professional Air Purifier
Plastic got in shredder won't work,would like instruchions to take it apart to fix
Take out the paper bin. Look for and remove any screws holding the top part of the shredder to the base. Take the top off, turn it upside-down and you might be able to remove the jam. To take the top apart, remove all of the screws that are under or near the edge. Look out, it gets very messy when you take it apart!
Fellowes sells replacement gears for some of their shredders.
Mar 30, 2014 | Fellowes Manufacturing Powershred SB-97CS...
How do i take apart a brake switch
dont have to take apart brake light, just remove the under dash panel.then locate brake switch on the brake pedal mounting bracket,disconnect the brake light switch electrical connector and turn rotate switch counterclock wise slightly so it will unlock from holder dont take switch apart you have to replace whole brake light switch as a unit.
Sep 17, 2012 | 1999 Dodge Avenger
Take apart a wii console
Made a video showing how to take apart the Wii.
Dec 26, 2011 | Nintendo Wii Console
How long does it take to take the transmission apart. Not fixed just take it apart. I had a nissan maxima 2004 5 speed taken the transmission apart and they shop wanted to charge me $800. Is this right...
It shouldn't take more than a couple of hours, 3 or 4 at the most, to disassemble the transmission. Sounds a bit expensive for just taking it apart. I would check some other places.
Nov 12, 2010 | 2002 Mercury Mountaineer
How do I take apart a sony playstation 3 apart...the disc is stuck inside
your best bet is to not take apart your ps3 but send it or they will not fix it if you take it apart
Feb 22, 2010 | Sony Playstation 3 (PS3) Console
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Sony Vtg 80s Cfs-500 Stereo Boombox Ghettoblaster Am Fm Radio Tape Player Japan Logo
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
