Question about Rosewill Computers & Internet
Dell monitor e196fpf backlight on but no osd picture video
skotkolr
  • 558 Answers
SOURCE: dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Posted on Feb 17, 2009
graysand
  • 558 Answers
SOURCE: My Dell E151FP LCD monitor keeps randomly flashing OSD menu, help
The cable might be pinched or bad.Have you tried the monitor on another PC?
Good luck
Posted on Oct 17, 2009
  • 10406 Answers
SOURCE: Dell E196FPf lcd
It's been over 16 months since you posted this question.
Did you take the LCD to a qualified technician, for professional trouble-shooting?
Posted on Jan 02, 2010
budmrtn
  • 11361 Answers
SOURCE: Dell 19" LCD E196FPf monitor
Yes,
http://s807.photobucket.com/albums/yy352/budm/Dell%20%20E196FP%20Rev%20A03/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Posted on Feb 27, 2011
mcrenteria00
  • 18 Answers
SOURCE: dell ultrasharp 1907fp bad contrast
I have seen a few of these monitors that when the display is dark in certan area's this usually indicates that one of the CCFL lamps has gone bad or there is a problem with the Analog/Digital Board, you can find the boards on ebay, but be VERY Certain that the board you order is the same that you take out of the monitor, as there are a lot of monitors that use the same simular boards but they are all different.
Posted on Sep 29, 2012
Tip
How to open up / disassemble Dell E196FP Monitor
On my Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
on Nov 23, 2007 | Dell E196FP 19" LCD Monitor
Yes,
Feb 26, 2011 | Dell E196FP 19" LCD Monitor
Dell monitor E196FPF when computor turns off monitor stays on screen keeps changing colours,have to turn main power supply any ideas please.regards phil
This sounds like a "Screen Saver" in the monitor ... go in to the monitor's Setup and disable the screen saver.
Dec 10, 2009 | Computers & Internet
Dell E196FPf monitor power problem
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell E196FPf lcd
On the back side unscrew everything you can unscrew, then using flat screwdriver with 1/4" wide blade try to disconnect halves of plastic case, there are plastic fixers over the edges, inside, so try to not brake them all :)
Next, you will need to unscrew metal cover inside to get access to the PCBs. If monitor was killed by surge, most likely you will see what is fried there. Check fuse on the PCB.
Sep 14, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
My emachines monitor has no picture, hard drive is functioning properly. Monitor is black
if you do not get a screen with a LCD monitor its likely you have a inverter problem or BACKLIGHT problem. you might need to replace the LCD backlight or replace the monitor on the desktop.
check to see if the laptop can get a picture by plugging in a monitor to it, im sure theres a connection for external monitor.
theres also a FN (function key) command to switch from lcd to external monitor. always test before commiting to replacing a monitor.
The desktop, you might want to test another monitor on the desktop just to be sure the monitor is gone or dead. if you see on the monitor a OSD saying "No power or No Signal" or you can pull up the OSD(on screen display menu). then the monitor is not dead.
might be the computer even though the computer powers up doesnt always mean the computer is working.
i would check the motherboard for blown capacitors or funky smelling(burnt plastic)aroma. Make sure the computer is off before checking.
get back to us!
thanks
Jun 15, 2008 | Computers & Internet
DELL E173Fpb
On my similar Dell 19 inch LCD Monitor, E196FPf, there are 4 screws on the back, and you need to pry off the plastic bezel from the front. At the bottom of the bezel are 4 small slots where you can start prying carefully with a screwdriver.
Nov 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
32 people viewed this question
Top Rosewill Computers & Internet Experts
Jim Thurston
JustBeatOnIt
Level 1 Expert
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
