Question about Vivitar ViviCam 3780 Digital Camera
WONT STAY ON
MY 3780 VIVICAM WILL TURN ON WHEN I PRESS THE POWER BUTTON BUT BEFORE I GET A CHANCE TO SET EVERYTHING IT TURNS ITSELF OFF. WHEN IT COMES ON THE LCD LIGHT FLASHES QUICKLY AND WITHIN SECONDS IT TURNS ITSELF OFF REGARDS HOBBSEY
  • 1 more comment
  • vinze101 Jan 09, 2009
    i got problems with my vivicam 3780.. power on problem.. when i press the power button.. the power indicator will just blink for a second and then suddenly turn off. even the battery is fully charge
  • Orbi Mar 05, 2009
    I have the same problem with my ViviCAM 3780s. I just bought a new AAA battery. And when I turned on my camera, I noticed that the power is flactuating. Now, my question is what would be the possible problem with my camera?
    Please advise.
    Thank you in advance
    Jerome
  • makulitster Mar 14, 2009
    i bought a new battery for my vivicam3780's
    then after a couple of minutes its say low battery and its suddenly off by itself
    Problem Solver:
  • 5 Answers
Most cheap cameras have a limited software capability. This means that power to flash and memory are always active. This in turn drains standard batteries very quickly.
To increase battery time turn off the monitor and flash when not in use. In addition remove batteries when camera is turned off. This will slow down the draining.
For best results purchase rechargable AAA batteries. Best are Ni MH (Around 1000 mAH). this will allow you to take around 2-3 times more shots than standard batteries.
HOPE THIS HELPS
Posted on Jul 28, 2009
Hi All. I used the 3780s quite sucessfully for over 4 years. It has one critical flaw. It drains battery power quickly if kept in flash mode. In flash mode, you will get maybe 10-12 shots with alkaline batteries before its battery runs out. The solution is to not use the flash or buy a rechargeable alkaline battery power set. The other problem is of memory which is obviated by buying a Sandisk or Transcend flash card of >= 1GB. Hope this helps.
Posted on May 17, 2009
IiHt happened to me BUT...! i qot maxwell batteries and iiHt stoped(: but i just dont know how to zoom): your welcome.......
Posted on Jan 08, 2009
Mine does this too, and the good batteries work for about a minute. I feel your pain, but this is a **** camera.
Posted on Nov 05, 2008
Check your batteries...sometimes cheap batterie or regular batteries do the same to mine...you may need to spend the little extra and purchase batteries for a digital camera ect....good luck
Posted on Feb 03, 2008
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Hitatchi 42pd8700 turning itself on
You have main board issues, there is a 3.2 volt regulator on your TV that gives issues and will make the set turn on at random times, replace the main board and it should fix it, or you can order the part for under a buck from China and replace it yourself if you have soldering skills
Jan 30, 2018 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
My S350 powers on when I press the power button, plays for 5-7 seconds and then powers off. What is wrong?
Mar 19, 2010 | Grundig S350 AM/FM/SW Radio
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
How do i zoom
1. Toggle the MODE button to camera picture and press the SET button
2. Compose your image while viewing the LCD monitor
3. Press the ZOOM thumbnail button with the magnifier picture to activate the digital zoom.can zoom images up to 5 times
4 Press the shutter button to capture the ZOOMED image
Hope this helps, there wasn't a date on your e-mail so not sure when your Holiday was.
Good Luck
Missy S
Sep 03, 2008 | Vivitar ViviCam 3780 Digital Camera
Won't stay on
A faulty switch or circuit board damage.
Contact Vivitar for repair or replacement[depends on age of camera]
Oct 23, 2007 | Vivitar ViviCam 3780 Digital Camera
Cameras Logo
197 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
