Question about Cycling
Next power climber
I need the nut that holds pedal on the sprocket
4 Suggested Answers
SOURCE: I want to replace the main sprocket with a bigger
You will need to purchase a crank puller to remove the cranks from the square tapered bottom bracket spindle. You can find these at amazon.com, and I would recommend a Park tools brand (about $14.00, plus S&H).
As to replacing the front chainring, the stock chainring is a 38 tooth unit, staked onto the right-hand-side crank. You will actually need to get a smaller chainring to make pedaling easier for you.
You can do this, but it will entail some very judicious parts choices on your part. If you feel that this isn't something that you'd like to do yourself, you will probably want to take the trike to a COMPETENT and CUSTOMER SERVICE-oriented bike shop, and have them either change the cranks and chainrings, or install a 3-speed hub, like the newer trikes come with.
Another option would be to just buy one of the new trikes which do have the 3-speed hub installed, but I'd recommend asking the bike shop owner if it would be alright to try it out first.
Posted on Sep 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: I cannot find a replacement nut that holds the
They're called chainring bolts and they come in a few different lengths - through one, two or all three rings.
Hundreds of them on eBay cheap. eBay search "chainring nut" with "double" or "triple" as required. They also come in light alloys and colors.
Most use 5mm allen key or torx T-30, but not both.
They require a special tool to hold the rear (flat part) still while tightening the front. Chainring Nut Wrench Park CNW-2 or Shimano TL-F-Y13009700.
eBay search "chainring nut wrench"
A BikeShop can advise you further.
Posted on Mar 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: i need to find a parts list for my Next Power
What exactly are you needing help with? Most bikes are just static frames with a bunch of aftermarket (Shimano, for example) stuff hung on them.
Except for proprietary frames or technologies, everything on a common bike is found on just about any other brand of bike and the individual components are usually documented at the individual manufacturers' websites.
Places like http://www.parktool.com/blog/repair-help document many of the repair and adjustment procedures.
Search Engines will find tons of How-to videos for assembly and adjustment if you just type in the basic question.
Posted on Jul 09, 2011
Remove sprocket
You can only do this with a sprocket removal tool, avaiable at bike shops. Should cost less then $5
Jul 30, 2014 | Next Power Climber 26-inch Dual-suspension...
How to remove foot pedal
Hi Anonymous, remove brake rod clasp pin. Remove master cylinder without disconnecting brake line, remove small plastic clip that holds brake line to sprocket cover, remove sprocket cover to access nut holding foot rest mount, remove mount and break pedal. Good luck.
Feb 11, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Stairmaster left pedal clanks
The "clunking" you are describing is more than likely caused by either a faulty left drive sprocket, the drive shaft or a combination of both. The drive sprockets are equipped with a needle bearing type clutch. When they fail, the clutch does not grab the shaft and drive it correctly. You may just need to replace the left drive sprocket. In some cases you will need to replace the sprocket and the drive shaft.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Sep 30, 2013 | Stairmaster Exercise & Fitness
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
I have a Stairmaster 4000PT. When using it, the left pedal will suddenly drop to the floor. Opened the case. The spring is intact. I used it with the case open and didn't notice anything different...
Sep 02, 2011 | Stairmaster Exercise & Fitness
Trying to get right side foot peg case off foot peg seems to have a nut behind case not sure how to get off
Yes there is a nut on the backside of the stud that the peg mounts to. The stud is also the shaft for the rear brake pedal. To get to the nut, take the master cylinder loose and the snap ring that holds the rear brake pedal on or the remove the pin from the brake pedal. Now, take the large nut below the peg and brake pedal shaft off and the other two bolts that hold the front sprocket cover on. Remove the cover and you can get to the nut.
Good Luck
Steve
Apr 03, 2011 | 1993 Harley Davidson XLH Sportster 883
How to take the sprocket and pedal arm off?
There should be a large nut holding the sprocket to the frame. first remove the pedeal rfom the side where the nut is. Then remove the large nut counterclock wise. remove the washer and behind the washer is a ring of ballbearings. It should be easy to remove after that. Hope this helps.
Mar 17, 2011 | Cycling
Want to replace drive sprocket on motor how do you get it off
Your sportster is actually pretty easy to change the front sprocket on. On the right side of the bike, you'll see the rear brake master cylinder. The master cylinder must come off as well as the plate that the master cylinder sits on. To get this off, you'll have ot remove the brake pedal and the exhaust system.
Once you get the plate off, you'll need some special tools to remove and replace the front sprocket. You'll need a special socket to remove the large nut holding the sprocket on and a special device made to hold the sprocket so you can get the nut off and then back on with the proper torque.
In addition to changing the front sprocket, you'll also have to change the final drive belt to match the size of the rear sprocket and front sprocket combination.
Good Luck
Steve
Dec 09, 2010 | 2006 Harley Davidson XL 1200 R Sporster...
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
Left pedal on stepper falls to ground in workout
YOU MAYBE HAVING AN ISSUE WITH THE SPROCKETS THAT HOLD THE DRIVE CHAINS ON BOTH PEDALS. YOU CAN PURCHASE THEM SEPARATELY OR A COMPLETE HUB ASSEMBLY. TO REACH STAIRMASTER/NAUTILUS @ 1-800-864-1270
Feb 26, 2010 | Stairmaster 4600PT Stepper
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
