Question about Emjoi Gently Gold Caress AP-9GAR Epilator
Tweezers no longer plucking, and the speed has slowed down
Where can I find a good tweezers
It's tweezing hair my dear, your not a chicken
Any store that sells health and beauty aids
Grocery store, Dept store, Drug store
Look for angled flat tips not pointed.
Nov 28, 2015 | Miscellaneous
I have a unibrow ie my eyebrows dont really separate in the middle. What can I do about it?
Tweezers are a good way of shaping and getting eyebrows under control, but if you have a uni-brow then you will need a more long term solution otherwise you could end up plucking your eyebrows every day!
Look into laser treatments or electrolysis for a more long lasting solution.
Feb 18, 2013 | Health & Beauty
How do you remove hair from your eyebrows with tweezers?
It's good that you're asking because if you want to pluck your own eyebrows with tweezers, you really need to do your research first so that your don't end up looking really silly.
Take a look at this feature on Oprah's website. It gives a really detailed tutorial about plucking your own eyebrows and what shape to choose etc;
http://www.mako.co.il/mako-vod-mako/documentary-s1/VOD-343177f0c077e21006.htm
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 | Watches
The motor on my shredder will only run in reverse
You need to remove the top section, make sure it's unplugged, and use a tweezers or very narrow needlenose pliers, and pluck out any paper chunks, and use canned air to blow out the paper dust. Reverse only means the chopper thinks there is paper jammed inside and will only run in reverse to clear the jam.
Jan 31, 2010 | Aurora Electronics AS662C Shredder
I have a 42" Philips Plasma HD tv and today it has been cutting off every few hours, its not the first time but it doesnt always happen either. When it goes off I just press the stanby button and it boes...
Well it could be that your fan is blocked and or clogged.You can take a tweezers,turn the television upside down,and lightly pluck out the pieces of **** clogging it up.That should make your fan run and then your television wont overheat and auto-shutdown.Hope it helped
Oct 15, 2009 | Philips 42PFP5332D 42 in. Plasma...
Chair runs to fast in high speed. can it be slowed down
If you can alter the speed, there will be a dial on the armrests to turn it down, i presume you have 4mph and 8mph,the dial will adjust the speed , so that it takes longer to reach 8mph.
Sep 25, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Slow speed, fan coming on loudly in Dell D800
Yeah the slowdown is the laptop throttling back due to overheating.
When you do processor-intensive work like - streaming videos - the laptop overheats. The fans come on loudly.
When the computer heats up despite the fans, the processor throttles back to relieve the heat.
When you reboot your machine, it stops performing intensive work, giving it a chance to cool down. It's not restarting that fixed the problem it's the fact that the laptop cooled down.
So here's what you do. Get an air duster and blow all the dust and gunk out from your fans. They are most likely clogged with dust and that's what's causing your cooling problems. If there are large dustballs in there, use a tweezers and pull them out. Get as much out as possible.
Dec 06, 2008 | Dell Latitude D800 Notebook
Emjoi Gently Gold Caress AP-9GAR Epilator Logo
66 people viewed this question
Top Emjoi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Emjoi Health and Beauty Expert? Answer questions, earn points and help others
