Question about AEG Dryers
AEG model T56840L appears to have no power. There are no lights, no display, just nothing. I have checked power is getting to the machine end of the power cord.
    Sergeant:
  • 224 Answers
Sounds like a fuse on the control board is bad or the control board has failed, the control board can sometimes be reset by leaving the power unplugged for a few hours, then plugging back in, (this will not work if the fuse or control board is bad) if either are bad, they will need to be replaced
Posted on Oct 17, 2013
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
I have an AEG T56840L dryer. All of a sudden no power. No LED display. No Drum light. There is power at the socket and I have changed the fuse in the plug. Any thing I can do myself?
Yes - check the plug at the line and check for power when the back cover is removed on the other side of the line. Often a single wire can come loose - be careful - this is 220 VAC
Oct 05, 2013 | AEG T57800 Electric Dryer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
My machine is 3 years old and used on average four times a week. It not worked hard as we work in offices, so no heavy overalls. Last saturday it stoped half way thru a washer cycle. The door remained...
Easy, scrapped it and purchased an Indesit. The cost to repair AEG was more than buying a new machine. I would suggest to anyone reading this never invest buying AEG unless you have a live in washing machine engineer.
Jan 26, 2010 | AEG Washing Machines
I have an AEG Oko Favorit 8081 dishwasher and it appears that there is no power getting to it [nothing light up] I have checked with a voltmeter and power is getting to the back of the machine. Is there a...
there is no fuse or breaker in appliance.
take outer door panel off and check for breakage in the wiring loom where it enters the bottom of the door. check also the door interlock is operating ok
Nov 12, 2008 | Dishwashers
AEG Lavamat E1050 End light blinks 5 times.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Jun 01, 2008 | AEG Lavamat W1050 Front Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryers Logo
392 people viewed this question
Top AEG Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you an AEG Dryer Expert? Answer questions, earn points and help others
