Question about Irons
Tefal 8460 sole plate needs replacing- is it the same as the (readily available) sole plate for tefal 8360?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
It probably is, 8460 is likely a newer style with few more bells and whistles..like the anti calc..I'd make sure whom ever you buy it from (the 8360) they will take it back if not correct.
Posted on Oct 18, 2013
5 Suggested Answers
  • 512 Answers
SOURCE: leaky water from sole plate
Open up iron, see if hose connected to tank came off. If you dropped iron a few to many times you could have cracked tank. Open up and you will see problem.
Posted on Jul 17, 2009
SOURCE: sticky black mark under my tefal iron
yes i did fix the probleme thank you. I did not that if i use you it would cost money.
Posted on Oct 06, 2009
  • 571 Answers
SOURCE: sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Posted on Nov 04, 2009
ercupa190
  • 12223 Answers
SOURCE: as the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
see this causes and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Posted on Oct 03, 2012
I have a tefal pro express steam generator iron. The thermostat light will no longer come on and water is coming out of the sole plate (as it does when you do a self clean) there is plenty of steam so I...
There is something definitely wrong with the mechanism and seal. The lamp might have been affected likewise. I think you need to replace your iron. If you can, you can try to repair it but the parts are hard to come by. Specially the silicone o ring.
Sep 03, 2013 | Irons
Handle loose
Just look around for a loose screws, and tighten the screws. Should be a quick easy fix.
Nov 13, 2012 | Tefal Pro Express GV 8120 Iron
TEFAL STEAM GENERATOR GV8460 NO STEAM IRON HEATS UP
The water is heated by a metal plate that is bolted to the metal water tank, operating in pretty much the same way as a domestic kettle, the plate being the element. The plate is fixed in place by 8 or so nuts onto studs that form part of the water tank and heated by passing electrical current into this plate. Over time the nuts come loose and consequently the plate is not in full contact with the water tank. This results in insufficient heat transfer and a failure to consistently reach the required temperature to create steam. Ultimately you will need to remove the plastic base of the unit to access the plate and re-tighten the nuts. You will need a small 6 star bit with the centre punched out to remove the base as it is secured with security screws. These are readily available on ebay as they are the same as those used to secure number plates.
Apr 27, 2012 | Tefal Pro Express GV 8120 Iron
Something burnt on the bottom of soleplate. Will not iron off.
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Nov 29, 2010 | Tefal Ultraglide 1549 Iron
Clean soleplate
heatman101
Jul 02, 2010 | Tefal UltraGlide 1759 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Sole plate leaking
Nov 04, 2009 | Tefal Irons
Sticky black mark under my tefal iron
Oct 06, 2009 | Micro Pro 7599 Iron
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Irons Logo
67 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
