Question about Minolta Office Equipment & Supplies
Konica minolta bizhub pro c500 sc code 29-21 - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,674 Answers
Remove the cyan drum and clean the very small sensor with a brush or can air. The senor is a tiny square on near the front section of the drum and behind when you remove the drum you will see it. If that does not (DO NOT USE A VACCUM CLEANER) The static electricity fro the vacuum cleaner will destroy it.) need to replace the drum or the sensor worse case to image control board that the sensor talks to. (swap a drum see if the changes it)
Posted on Jan 23, 2015
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
I need a technician in metro atlanta who has expierence with konica minolta c500 or 8050
contact the manufacturer we have no idea who does that service for them anywhere
Nov 17, 2015 | Konica Minolta Bizhub Pro C500
Error sc 33 01
fuser code reset in service 25 mode.
Jun 04, 2014 | Konica Minolta Bizhub Pro C500
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
Feb 20, 2014 | Konica Minolta Bizhub Pro C500
Error code sc 30-02
Can you tell me your detail questions ?
Jul 21, 2013 | Konica Minolta Bizhub Pro C500
Konica minolta bizhub pro c500 error code sc29-19
check, the drums, no scratches, if good the surface of the drum, interchanges the drum, for example, move the drum cyan to the drum yellow.
Jun 07, 2012 | Konica Minolta Bizhub Pro C500
HELLO SIR BIZHUB PRO C500 ERROR CODE SC 29-06 AND SC23-09
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fuser problem, Warm-up incomplete
May 10, 2010 | Minolta bizhub 200 Copier
ERROR CODE SC45-20
HAVING A REPORT CODE SC 45-20 HOW TO SOLVE IMMEDIATELY FOR PRINTER/COPIER BIZHUBPRO C500
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
149 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
