Question about Microwave Ovens
I have 5 lts pressure cooker.i am not getting whistle.water is leaking from sides.i have changed the vassels/gas cut.still problem not solved,whats the problem,what can i do,help me please.
  • Microwave Ovens Master
  • 2,113 Answers
What is the brand name and model number?
Posted on Oct 17, 2013
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
The fire output is very low and we can smell a small amount of lpg we have changed the gas regulator but it did not solve the problem
You must have either the wrong regulator, or low incoming pressure to the regulator and with the smell of gas I would suspect a leak in the system. Check all fittings on the lines with windex to see if you see it bubbling along any of the connections, if it is bubbling you have a leak. A better product to check for leaks is Snoop, but if you can't find it windex will work.
Jun 12, 2011 | Microwave Ovens
I have just purchased this appliance from the local Hospice shop. It has the top pressure balance knob thing (if this is any help) but I have no idea how to use it. There is alot of information on sites...
Just sounds like an old school pressure cooker. Look up Pressure cookers online and you should be able to find instructions. Try looking up this, is this what you have??
Presto 01362 6-Quart Stainless Steel Pressure Cooker
Aug 24, 2017 | Microwave Ovens
E1 error was shown on induction cooker.Please give me a way to solve this.
Possible that the driver of the induction coils is short or damaged. You might need to remove the panel and check within to see the reason for the protect cut off.
If there is no other display on switch On then the circuit is faulty and a knowledge of power electronics is needed to probe into the circuit.
Mar 16, 2011 | Microwave Ovens
How do I use my Bene Casa rice cooker? Do I add the water and rice and salt at the same time? How long does it take? I always use 1 cup rice when I make it in a pan on the stove, with 2 1/4 cups water. ...
I have a Bene Casa Pressure electric cooker given as gift but has no instruction book. I need to know how to put pressure on it when I am doing chicken, If any knows it would be appreciated.
Jan 31, 2011 | Microwave Ovens
I have a belling range gas cooker, i have just changed the thermo couple but now the gas is not coming through as much as it should, the relaese of gas is normally fast and you are able to hear it but now...
There is no reason why the gas level has dropped after the thermocouple was changed but the ONLY reason can be an accidental fault in the fitting or refitting.
So go over the same job and check from the gas line, the regulator and the burner. Use a good air jet to blow the passage clean. make sure there is good contact of the burner to the base for a good fuel mix.
check if there was any restriction inthe gas flow when the fitting was done. The fault can be only here, remove gas and use a air pressure to check the flow line, clean and set back.
Sep 18, 2010 | Microwave Ovens
Hi,My pressure cooker is not giving whistles.It is happening since two days.It had worked properly for the past 1 year.Safety valve is gud.I cleaned the pressure nozzle.There is not obstruction in pressure...
Take the vent apart and clean it in vinegar and water solution...there is mineral build up inside that stops it from whistling....
heatman101
Aug 27, 2010 | Microwave Ovens
Have a used cooker-no instructions. What pressure/for how long to cook stuffed peppers?
Hi. 15 psi for 20 minutes. Here is the recipe STUFFED PEPPERS Printed from COOKS.COM
1 lb. hamburger
1/2 c. uncooked rice
Onion
Onion salt
Garlic salt
Celery salt
Tomato sauce
Green peppers
Combine hamburger, rice, onion, seasonings, and a half can of tomato sauce. Stuff mixture into peppers loosely. Dot with butter. Pour remaining tomato sauce over pepper. Place in a pressure cooker. Pour water in to almost cover peppers. Pressure cook for 20 minutes.
Jun 24, 2010 | Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
