Question about Samsung R519-53S Notebook
After removing cmos battery in Samsung r519 and insetting it, the machine cant power on...what I see is a charger indicator LED only in a green state even when the charger is plugged off
    Habit-Forming:
    New Friend:
  • 110 Answers
Try a new cmos battery and make sure you use cloves before touching the battery
Posted on Oct 23, 2013
  • 2567 Answers
SOURCE: My Samsung p400 laptop won't power on. There are
1. Take the battery out of the laptop & try to turn on the laptop using power
adapter only. If the computer turns on, then the battery is defective & needs to be
replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the
power adapter using a voltmeter. Compare the voltmeter reading to the nominal value
written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re
-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
  • 2567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
6. The motherboard could be defective & needs to be replaced.
Testimonial: "thanks for the answers. "
Davethesnake
  • 689 Answers
SOURCE: hi i have a samsung r519 and i carnt figure out
check originality of the P.S.U.--check it is the correct item running at the stated values.Check the polarity of your connection,this is printed on the side of some units its like a small ball surrounded by a "C" check you dont have one of those universal P.S.U's which have connectors that have to be correctly connected --look for a small "arrow" on the side of the connection denoting correctly plugged in.
Posted on Feb 27, 2011
  • 362 Answers
SOURCE: battery not charging samsung nc10-
try holding the power button for 30 secs with the battery out and unit powered off it allows a static discharge and might help its what my wifes g60 requires from time to time good luck and hope this helps you out some
Posted on Mar 22, 2011
Geekman
  • 32281 Answers
SOURCE: Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Posted on Sep 03, 2012
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Flashing orange laptop light on samsung laptop
If your battery is six years old, it has done very well and you have looked after it. I would think that a new charger will fix your problem.
Dec 21, 2013 | Samsung R519-53S Notebook
My samsung r519 laptop is not charging i have bought a new charger dont know why not charging could it be the battery
the most likly suspect is the socket in the laptop, after some time they get warn and the connections on the motherboard come loose if you take it to a pc repair centrue for a fee they can disassemble the laptop and re solder the socket to the board.
Jun 04, 2012 | Samsung R517 R518 R519 R522 Laptop Lcd Led...
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
No power even with new PS. Green LED comes on but
Try removing the CMOS battery & see if the motherboard will power up or not without it. If it did, then your CMOS battery is defective & needs to be replaced.
Dec 22, 2009 | Intel D865GBF Motherboard
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung R519-53S Notebook Logo
88 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
