Question about Bose Companion III Computer Speakers
Creative gigaworks t3 volume control has been lost how to operate that speaker without volume control ?
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
I have a Creative Gigaworks S700 i have checked both fuses still no power to control box
Stupid question: does the sound still work? it could be the LED just died after continual use (rare, since they last a long time, but not uncommon).
If not... it could be the controlling circuit board died. In which case, unless you have electronics repair experience, it would be probably more worthwhile to just replace the speakers, as pricey a model as it is.
Mar 23, 2012 | Creative Labs Gigaworks S750 Computer...
Cambridge Soundworks Gigaworks S750 I left the system on standby over the night next day no sound or some fuzzy sound from the speakers..Is it the remote controller or the whole system went...
To make these your default speakers, you will need to do the following 1. Find the volume control icon on the bottom right portion of your screen 2. Right click the icon 3. Select change default 4. Cycle through the options until you see the logitech speakers as an option 5. Select this new option 6. If you still do not see the logitech speakers then you need to reinstall them with the provided software. If you do not have software, download it for free from logitech.com
Jan 22, 2011 | Creative Labs Gigaworks S750 Computer...
WILL CREATIVE GIGAWORKS T3 WORK ON A LAPTOP
All you should need to do is plug the speakers into the headphone jack on your laptop. This will turn off the internal speaker(s) on the laptop and route the signal to your T3 speakers.
Dec 06, 2010 | Creative Technology Gigaworks T3 2...
I cannot get my t20 speakers working, i have just had a new sound card fitted, the green speaker level is going up and down but no sound
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 02, 2010 | Creative Labs GigaWorks T20 Computer...
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Creative s750 speaker distortion
The volume in your system and your television is separate. Mute your television, and rely only on your system.
Sha'ul
Jun 27, 2009 | Creative Labs Gigaworks S750 Computer...
All I need is the control pod for the Gigaworks S750
I had an extra one but I sold it. According to creative labs they do not sell any replacement parts for the speaker systems. The best suggestion that I can give is to check craigslist and ebay for the control pods.
Dec 13, 2008 | Creative Labs Gigaworks S750 Computer...
User Manual Creative G500
Gigaworks manual is just one sheet, you need to download both following links to pdf documents.
Link front
Link back
Jun 22, 2008 | Creative Labs GigaWorks ProGamer G500...
Bose Companion  III Computer Speakers Logo
93 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
