Question about 1994 - 2001 Lexus ES300 Engine Timing Belt Component Kit W0133-
HELP ME ON MY HYUNDAI SONATA 2.4 CAM TIMING CHAIN MARKS
    Scholar:
  • 45 Answers
Use this image to rotate both cam marks to the correct location at the top. Remove the spark plug from #1 cylinder and place a dowell or long screwdriver into the sparkplug hole. Rotate the crank to top dead center on #1 by using the marks on the front of the crank balancer AND confirming with the motion of the dowell in the cylinder (as it rests gently on the top of the piston).
Put the timing belt on and adjust the tensioner. BEFORE cranking the engine use white nail polish/whiteout to place marks on the belt, cam and crank gears. Crank and start. If it runs rough, Examine the white dots and adjust accordingly.
Posted on Oct 19, 2013
Timing marks on cam for timing chain 2007 Hyundai accent
right it a twin cam engine
the cam chain between the two cams
depends what cams are there
do these help
May 18, 2016 | 2007 Hyundai Accent 1.6
Camshaft timing marks
Hi all. I am looking for the timing marks on a Hyundai Sonata Vivante V6 2.5lt Eng. Te camshafts Sprockets do not have any marks (chain driven) Thanks Andries.
Jan 12, 2014 | Cars & Trucks
I have 1998 hyundai excel twin cam l have just put cams out of 1999 excel and it sound like it has a lumpy cam now at lidle.Now my car smells like unburnt fuel.can this be from cam not being in right at...
double check all youre timing marks . loosten tentioner and adjust cam.then tighten chain .manually turn motor over twice then check timing marks again this is a little tricky sometimes because when you tighten the tentioner the cam will move. you have to have the chain in a spot to compensate for this movement.
Dec 02, 2013 | Cars & Trucks
I need a diagram of timing marks for a hyundai sonata 98 2.5L EF
Yoy will get a diagram and how to do it from a workshop manual (Gregorys or haynes) as it is involved to explain here. Strongly suggest you have a hyundai qualified mechanic do it as it will save you money in the long run. IT is not just belts that need replacing but idler pullets and hydraulic adjuster (if you have one) as well as crank seal and cam shaft seal. Oil is the biggest killer of timing belts and all except the pulleys have oil in their presence.
Mar 08, 2013 | Hyundai Motor 1998 Sonata
Can a sonata bent valves if cam belt snaps and what is the timing marks 2.0 gls
The sonata has a 16 valve machine and works with a timing belt and not a timing chain. if the belt snaps it will bend the valves. not all the valves but some of them. a secondhand top with valves shouldn't be expensive. I would change all the valves. sometimes a valve cen bend so minimal it can't be picked up by the eye. you don't want take the top off again. it's a fairly simple machine. a mechanic should help you with the timing once you're done. good luck
May 07, 2010 | 1997 Hyundai Sonata
Getting P0011 code on Hyundai Sonata. Can anyone tell me what it means?
more than likely you have a bad oil control valve if in fact you have an 06 sonata. They are chain driven engines... You can ohm out the valve and get a good reading even when the valve is bad. Pull it out and check to see if it is clogged, if it is thats more likely your problem. If it is clean, go ahead and replace the valve. Hyundai calls them the oil control valve (OCV) and usually located on the head close the the variable valve sprocket.
Dec 18, 2009 | 2006 Hyundai Sonata
2002 Hyundai Sonata have a timing belt or chain
timing belt and yes the belt and tensioner needs changed every 60k and if its a 4cyl. the balance belt also needs replaced
Aug 18, 2009 | Hyundai Motor 2004 Sonata
Timing marks 2002 sonata 4 cyl twin cam balance shaft marks
look for marks on the timeing gears there sould be a couple notches. then bring them center to center
Dec 24, 2008 | Hyundai Motor 2002 Sonata
1994 - 2001 Lexus ES300 Engine Timing Belt Component Kit W0133- Logo
126 people viewed this question
Top Gates Vehicle Parts & Accessories Experts
Lodhi Autos
Lodhi Autos
Lawrence Oravetz
Frank Magliocca
Are you a Gates Vehicle Part and Accessory Expert? Answer questions, earn points and help others
