Xerox workcentre 24 error 006 227 - Computers & Internet
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
SOURCE: LSU Error
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
Posted on Oct 13, 2008
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 2072 Answers
SOURCE: What is error 010-333?
That is a fuser over heat code. You will most likely have to replace the fuser module. Or have service do that for you.
Posted on Jan 05, 2009
acsmappel
  • 61 Answers
SOURCE: Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Posted on Aug 04, 2009
Where can I purchase DRUM cartridges for my Xerox Workcentre 24 as I need Magenta and Cyan immediately?
go to www.partsdrop.com or aaatoner.com
or if you want immediate supply go to your nearest xerox store and purchase it if you are in new jersey partsdrop is the wholesale dealer and they will give you drums and toners in wholesale price
May 08, 2014 | Xerox WorkCentre M-24 Color Copier
Xerox m-24 error code 008-175
The Registration Sensor does not detect paper fed from the MSI
Nov 11, 2013 | Xerox WorkCentre M-24 Color Copier
WorkCentre M24 is ticking me the error code 010-398
You have a bad fuser fan. Xerox part number 127K29340. Located on the back of the machine. Very common problem. Look up on google a business called the parts drop.
They will have it.
Mar 10, 2011 | Xerox WorkCentre M-24 Color Copier
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
I have a Xerox workcentre 7345 and reported that the Error code 010-341. I Had already replaced Fuser. stil Getting the Same error code
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre 24 error code 116-385
An internal shutdown occurred after an IDC (scripting language) processing error.
arrwup.gifInitial Action Power Off/On
arrwup.gif Procedure Reseat the ESS ROM and NVM PWBs. If the problem persists reload software ( GP 7).
If the problem persists, replace the ESS PWB ( PL 13.2).
Apr 24, 2008 | Office Equipment & Supplies
Reset WorkCentre 24, Xerox
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
