Welding Tools Logo
Posted on Apr 25, 2009
I have a century 250 mig wire feed modle 117-042 and today I was in the middle of a weld and it was if the heat got turned down and I can no longer weld. I tried turnning it up, and still not enough heat. It has just enough to make the wire stick but thats all. please help
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Apr 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
11198
Points
38
Sounds like a fried board, or rectifier
3answers
What is the difference between TIG & MIG welding?
MIG welding is also called Metal inert gas welding, gas metal arc (GMAW) welding. MIG welding uses an arc of electricity that creates a short circuit amidst a constant anode and a cathode. The short circuit produces heat and a non-reactive gas. This melts metal, enabling it to be mixed together. After the heat is removed, the metal cools down and then solidifies, creating new fused metal. MIG wire is used in MIG welding. Tungsten inert gas (TIG) welding utilizes a non-consumable tungsten electrode that produces the electric arc for the weld. Unlike MIG welding, TIG welding does not require additional metal to be added.
1helpful
2answers
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Welding will not hold
turn your heat wire speed up hope for the best too small of a machine
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
4helpful
1helpful
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
1helpful
4helpful
2answers
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
