My AIWA A219 TV colour are suddenly changed. Bottom side colour are OK but upper side colour are like red & green. One day my TV had sudden switch off. After that I was change the fuse & after that when I was switch on my TV that time to still I am facing this problem. Please solve my problem.
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
It sounds that the 'Degaussing" posistor have damaged. My AIWA A219 TV colour are suddenly changed. - 89b6267a-1d0d-4e28-891b-00182012094c.jpgIt will look somewhat like this.
Posted on Oct 17, 2013
ctf1800
  • 4402 Answers
SOURCE: Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Posted on Feb 11, 2008
Benimur
  • 6966 Answers
SOURCE: CRT TV vert section
Vertical linearity is more of a DCV bias issue rather than feedback or AC coupling. Hence it would be more apt to suspect resistors rather than capacitors. Of course, it is also possible that the large IC that drives the Vertical output maybe at fault (least likely) but often would have trimpots for adjustment. Most current designs do away with trimpots and rely on self correcting (feedback loop) which is simply a resistor in the 100k range. In certain instances, it could be a thermistor or resistor or diode limiter attached to the yoke itself.
Best would be to use a service manual or at the very least a schematic diagram with voltage readings and compare actual on PCB against schematic.
If you could post back the make & model or preferably the chassis number of the TV, might be able to comment back known common vertical issues.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 06, 2008
Bennytechkid
  • 99 Answers
SOURCE: Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Posted on Aug 13, 2009
  • 189 Answers
SOURCE: colour problems on TV
HELLO
I think what you have here is a degaussing problem causing purity errors on colours. When you switch your TV on there is a coil around the rear of the tube which is connected to a posistor and this is to get rid of any residual magnetism.
It sounds like the circuit is not working correctly possibly caused by a faulty posistor. Another reason could be that you may be using the set by putting it in standby all the time - the degauss does not work as it should by doing this - the best way is to switch it off properly after use and on again by the switch on the TV itself.
If the problem does not go away, then you'll have to get a service engineer to sort it.
I wish you well with your problem (:-)
Posted on Sep 25, 2009
SOURCE: my aiwa tv-- A219 is
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Posted on Jan 30, 2011
In aiwa A219 model colour tv chanels not stored during autosearch.
Main system control memory IC fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 20, 2015 | Aiwa Televison & Video
My aiwa a219 tv is show aging 2f91h in red color,plz help me.
Possible the red gun is going bad In the CRT. Would need hooked up to a CRT tester to find out.
Jan 18, 2015 | Aiwa Televison & Video
Error codes
Its main system control memory IC is damaged. Replace it with same number. This IC is a very small one, having 8 solder terminals, and can be located very near to the main system control IC. Usually start with a number 24C**. Check and replace it. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | Aiwa TV-S2011 20"
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
Feb 07, 2012 | Aiwa TV-S2011 20"
I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 3CDDH
Hello
Its front panel microswitches are struk. These can be replaced. They are microswitches, which can be resoldered out from the front panel board. For this, you have to open your TV, take out the front panel after unscrewing it from the cabin, desolder one out of it and go with that microswitch as sample. You can bought it from electronic spare part shops at your town. Buy all of them and replace all at same time. This will solve your TVs problem. OK.
Jun 17, 2011 | Aiwa F2000 20" TV
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Cable on TV suddenly went to black & white (and a bit fuzzy)(some channels show faint colour). Was fine, nothing was changed, one day was suddenly B&W. TV screen is not the problem, all other cable...
Was playing around with the TV's menu and changed the Tuning Band from "HRC cable" to "IRC cable". Suddenly I have colour again. No one had adjusted any of the controls, so still not sure why one day it was fine and the next day it had gone to black and white, but changing the Tuning Band fixed the colour problem for me.
Sep 13, 2009 | Televison & Video
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Feb 11, 2008 | Televison & Video
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
