Question about Samsung SyncMaster 713N 17" LCD Monitor
IS IT POSSIBLE THAT IT HAS SHORT CIRCUIT A MONITOR
P0351 code loss of power 2.3L08ford ranger,it warms slow and really need to eliminate1~voltage regulator is where?) & 2~ ground through PCM) 3~knowing limits&threashholds{sensorsIGNcircuit}?Ty 0$
P0351 loss of power ? That's not what this code is about . P0351 - Ignition Coil A Primary/Secondary Circuit ,you have a bad coil and possibly a bad coil driver inside the PCM . Do yourself a favor an take your vehicle to a qualified repair shop !
P0351 - Ignition Coil A Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0350 - Ignition Coil Primary/Secondary Circuit Description: Each ignition primary circuit is continuously monitored. The test fails when the powertrain control module (PCM) does not receive a valid ignition diagnostic monitor (IDM) pulse signal from the ignition module (integrated in the PCM). Possible Causes:
  • Open or short in the ignition START/RUN circuit
  • Open coil driver circuit
  • Coil driver circuit short to ground
  • Damaged coil
  • Coil driver circuit short to VPWR
Diagnostic Aids: Use the 12-volt non-powered test lamp to verify START/RUN voltage at the ignition coil harness connector.
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test JE .
Feb 18, 2017 | 2008 Ford Ranger
WHAT DOES P0123 MEAN?
SYMPTOM
P0123-THROTTLE POSITION SENSOR VOLTAGE HIGH
WHEN MONITORED
With the ignition ON and battery voltage above 10.4 volts .
SET CONDITION
Throttle Position Sensor voltage at the PCM goes above 4.5 volts for 3.2 seconds .
POSSIBLE CAUSES
  • Clock spring shorted
  • Throttle position sensor sweep
  • Intermittent condition
  • Throttle position sensor signal circuit shorted to 5 volt supply circuit
  • Throttle position sensor signal circuit shorted to battery voltage
  • Throttle position sensor internal failure
  • Sensor ground circuit open
  • Throttle position sensor signal circuit open
  • PCM
hope this helps, Tim 423 327 4108
Jun 06, 2014 | 2001 Dodge Dakota
Replaced timing belt and water pump on a 2005 dodge neon with a 2.0 it starts and idals great but you press or reve it up it backfires through the intake and pulls up code p0344. whats the problem.
Hi Ricky, I'm glad to help. Below is the possible causes for the P0344 code that you have.
Symptom:
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
When Monitored and Set Condition:
When Monitored: Engine running or Cranking.
Set Condition: When the failure counter reaches 20. One Trip Fault.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
WIRING HARNESS INSPECTION
(K7) 5 VOLT SUPPLY CIRCUIT OPEN OR SHORTED TO GROUND
TONE WHEEL/PULSE RING INSPECTION
CHECKING CKP SIGNAL WITH THE DRBIII
t LAB
(K44) CMP SIGNAL CIRCUIT OPEN
(K44) CMP SIGNAL CIRCUIT SHORT TO GROUND
(K44) CMP SIGNAL CIRCUIT SHORTED TO B+
(K44) CMP SIGNAL CIRCUIT SHORT TO (K7) 5 VOLTS
PCM
Apr 18, 2014 | 2005 Dodge Neon
I have codes 0122 0123 2104 2110 2111 2112 would it be the throttle body
Trouble Code: P0122
Throttle/Pedal Position Sensor A Circuit Low
Possible Causes:
Open ETC TP sensor harness.Short to ground in the ETC TP sensor harness.Damaged TP sensor.SIG RTN circuit open to the TP sensorPCM has failed
Trouble Code: P0123
Throttle/Pedal Position Sensor A Circuit High
Possible Causes:
TP sensor not seated correctly.TP sensor harness is short to voltage.TP sensor harness short to VREF.SIG RTN circuit open to the TP sensor.Damaged TP sensor.PCM has failed.Trouble Code: P2104
Throttle Actuator Control (TAC) System (Forced Idle)
Possible Causes:
Air cleaner and air inlet are not correctly seated.Check for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensor.Throttle Position (TP) sensor.Manifold Absolute Pressure (MAP) sensor.PCM has failed.
Mustang 2006-2008
4.0L V6 VIN N Auto 12
Print
Trouble Code: P2008
Intake Manifold Runner Control (IMRC) Circuit Open (Bank 1)
Possible Causes:
IMRC monitor circuit open
Trouble Code: P2014
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage or obstruction of IMRC hardware
Trouble Code: P2015
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 1)
Possible Causes:
Mechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2019
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2020
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 2)
Possible Causes:
Trouble Code: P2065
Fuel Level Sensor B Circuit
Possible Causes:
Communication link concernDamaged Instrument Panel Cluster (IPC) (MKS)Damaged Instrument Cluster (IC)Damaged PCM
Trouble Code: P2066
Fuel Level Sensor B Circuit Range/Performance
Possible Causes:
Trouble Code: P2067
Fuel Level Sensor B Circuit Low
Possible Causes:
Trouble Code: P2068
Fuel Level Sensor B Circuit High
Possible Causes:
Trouble Code: P2070
Intake Manifold Tuning Valve (IMTV) Stuck Open (Bank 1)
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorPCM has failed
Trouble Code: P2071
Intake Manifold Tuning Valve (IMTV) Stuck Closed Bank 1
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorIMTV circuit openPCM has failed
Trouble Code: P2072
Throttle Actuator Control (TAC) System (Ice Breakage)
Possible Causes:
Ice or oil in the intake air system could be the result of a Positive Crankcase Ventilation (PCV) system concern
Trouble Code: P2096
Post Catalyst Fuel Trim System Too Lean (Bank 1)
Possible Causes:
Loose connection, and damaged or corroded terminalsExhaust leaksContaminated HO2S
Trouble Code: P2097
Post Catalyst Fuel Trim System Too Rich (Bank 1)
Possible Causes:
Trouble Code: P2098
Post Catalyst Fuel Trim System Too Lean (Bank 2)
Possible Causes:
Trouble Code: P2099
Post Catalyst Fuel Trim System Too Rich (Bank 2)
Possible Causes:
Trouble Code: P2100
Throttle Actuator Control (TAC) Motor Circuit/Open
Possible Causes:
TAC motor has an open windingTAC motor is damagedTAC motor harness is openTAC motor harness is short to PWRTAC motor harness circuits are short togetherTAC motor harness connector is unplugged
Trouble Code: P2101
Throttle Actuator Control (TAC) Motor Range/Performance
Possible Causes:
TAC motor circuits are cross-wired
Trouble Code: P2104
Possible Causes:
Air cleaner and air inlet are not correctly seatedCheck for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensorThrottle Position (TP) sensorManifold Absolute Pressure (MAP) sensorPCM has failed
Trouble Code: P2105
Throttle Actuator Control (TAC) System (Forced Engine Shutdown)
Possible Causes:
Trouble Code: P2107
Throttle Actuator Control (TAC) Module Processor
Possible Causes:
TAC motor harness circuit short to ground.TAC motor harness circuit short to voltage.Damaged Electronic Throttle Body (ETB).PCM has failed.
Trouble Code: P2110
Throttle Actuator Control (TAC) System (Forced Limited RPM)
Possible Causes:
Trouble Code: P2111
Throttle Actuator Control (TAC) System (Stuck Open)
Possible Causes:
Binding throttle body, stuck open.TAC motor circuit open.TAC motor circuits are cross-wired.TAC motor harness circuits are shorted together.PCM has failed.
Trouble Code: P2112
Throttle Actuator Control (TAC) System - Stuck Closed
Possible Causes:
Oct 26, 2012 | 2006 Ford Mustang
What does the code po748 refer to
Symptom:
P-0748 GOV PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS
When Monitored: Continuously with the key on.
Set Condition: This code is set if the voltage detected on the Governor Pressure Solenoid
Control Circuit at the PCM is different than the expected voltage for 4.8 seconds.
POSSIBLE CAUSES
NO POSSIBLE CAUSES REMAINING
FUSED B(+) CIRCUIT OPEN
SOLENOID AND HARNESS ASSEMBLY DEFECTIVE
GOVERNOR PRESSURE SOLENOID DEFECTIVE
TRANSMISSION CONTROL RELAY DEFECTIVE
GOV PRESSURE SOLENOID CONTROL CKT SHORT TO GROUND
GOVERNOR PRESSURE SOLENOID CONTROL CIRCUIT OPEN
GOVERNOR PRESSURE SOLENOID WIRING HARNESS INTERMITTENT DEFECT
GOVERNOR PRESSURE SOLENOID WIRING HARNESS OBSERVABLE DEFECT
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
TRANSMISSION RELAY OUTPUT CIRCUIT SHORTED TO GROUND
PCM DEFECTIVE (GOV PRESSURE SOLENOID SHORT TO VOLTAGE)
PCM DEFECTIVE (RES IN RANGE)
PCM DEFECTIVE (GOVERNOR PRESSURE SOLENOID DEFECTIVE)
PCM DEFECTIVE (CONTROL CIRCUIT SHORTED)
PCM DEFECTIVE (SOLENOID & HARNESS ASSEMBLY DEFECTIVE)
Feb 03, 2012 | 1999 Dodge Dakota
P1537 how do I fix this problem?
CODE P1537 - INTAKE MANIFOLD RUNNER CONTROL MALFUNCTION BANK 1 STUCK OPEN. POSSIBLE CAUSES. IMRC MONITOR SIGNAL CIRCUIT SHORTED TO POWER GROUND. IMRC MONITOR SIGNAL CIRCUIT SHORTED TO SIGNAL GROUND RETURN. IMRC ACTUATOR IS DAMAGED OR THE PCM HAS FAILED. - IMRC - IS INTAKE MANIFOLD RUNNER CONTROL.
Sep 01, 2011 | 1998 Ford Windstar
Some times crt is not ON .corner green LED is ON and OFF.
The LED is cutting off because there is some short in the circuit, It can be a possible fault in the HT circuit a fault in the driver or the line output transformer.
You will need to check on the circuit after removing the rear panel , check the main power, disconnect power to the circuit to confirm the short.
Feb 22, 2011 | Samsung 793S 17" CRT Monitor
My 1997 chevy s10 is messing up I hooked up a obd2/eobd code reader and it gave me back this code......P1380 EBCM DTC detected, dada unusable? I have no clue what that code means but if you can help it...
P1380 - Misfire Detected Rough Road Data Not Available
The comprehensive component monitor (CCM) monitors the VCT circuit to the PCM for high and low voltage. If the voltage falls below a calibrated limit a calibrated amount of time during testing, the test fails.
Possible Causes:
  • Open or short in the VCT circuit.
  • Open VPWR circuit.
  • Damaged PCM
  • Open or short in the VCT solenoid valve.
  • Possible Solutions:
    DTC P1380 is a VCT circuit check. Testing should include wires, solenoid coil, and the PCM.
    Jan 17, 2011 | Chevrolet S 10 Cars & Trucks
    Dodge durango PO320 + PO700 + PO725
    SYMPTOM
    P0320 - NO CRANK REFERENCE SIGNAL AT PCM
    WHEN MONITORED
    With the ignition ON.
    SET CONDITION
    No signal from the Crankshaft Position Sensor is present during engine cranking, and at least 3 Camshaft Position Sensor signals have occurred.
    POSSIBLE CAUSES
    SYMPTOM
    P0700 - EATX CONTROLLER DTC PRESENT
    WHEN MONITORED
    Ignition key ON, Continuously.
    SET CONDITION
    Any DTC sets in the Transmission Control Module.
    POSSIBLE CAUSES
    Jun 04, 2009 | 1997 Dodge Caravan
    Benq Q7S3
    Video Graphics Card in Computer "BAD" !
    Nov 15, 2017 | BenQ FP567s 15" LCD Monitor
    Samsung SyncMaster 713N 17" LCD Monitor Logo
    13 people viewed this question
    Top Samsung Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
