Our hotpoint wt540 does not work. Choose any cycle and the wash light comes on and stays on. Then theres a small clunk from the machine but thats it. The door locked light is not coming on.
  • 42 Answers
There is a small electronic lock on the inside of the machine where the striker unit of the door locks into and it sounds as though this have malfunctioned. You can change this quite simply.
Power Off machine
Take metal band which hold on door seal
Peel door seal off and you can now put your hand in and take this interlock out
Sometimes the lock will have screws to secure to the body of the machine
The lock might have visible signs where it has burnt but sometimes it wont
You can buy this lock from a parts supplier by quoting the model number and serial or product number found on the inside of the door
If this fails to work you most probably have a fault with the main board not recognising the door lock. For reconditioned modules and mother boards you can goto http://emwelec.co.uk/
Posted on Oct 17, 2013
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Posted on Jan 01, 2009
barkencoa
  • 3463 Answers
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
Posted on Dec 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
Posted on Mar 19, 2010
beltronic205
  • 1467 Answers
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
Posted on Apr 07, 2010
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
How can I unscrew the drain outlet at the bottom front of my Hotpoint WT540? Our machine has completed a wash and drained, but isn't spinning. The door light flashes when I try and run a spin. I decided to...
Keep trying to unscrew it, as it should come right out for cleaning. A little water will come out too so put a small tray under the machine first.
Look at my other solutions, as for DOOR light flashing.
Apr 02, 2010 | Hotpoint Aquarius WD63 Front Load...
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Hotpoint wd420 clunking noises
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
May 17, 2009 | Washing Machines
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
I have a Hotpoint Aquarius WT540 and it will need complete its wash cycle and will not got the spin cycle. Two lights are flashing. I have took the bottom panel off to check the filter. I undid the...
just give it a tug. possibly tight because something caught in it - bra wire or similiar.
you may have a lot of water out so have towels handy and make sure it doesn't go on the motor
Jun 25, 2008 | Hotpoint Washing Machines
Hotpoint WT540 problem
You have to check your pump, probably clogged
May 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
