Question about MPC Computers ClientPro 375 (9557751) PC Desktop
Fan is really loud - MPC Computers ClientPro 375 (9557751) PC Desktop
Intensity vacuum really loud
Loud vacuum is usually a broken fan which requires pulling motor.
Jan 26, 2014 | Electrolux Vacuums
Acre z5700 turns off
A really loud fan can be one of two things - neither is very good to have for very long. Most newer motherboards support multi-speed fan operation based on CPU temperature. This keeps fan noise at a minimum because the fan only has to run fast (and loud) if the CPU exceeds a specific threshold temperature. The loud noise could also be from a fan that is starting to fail and is binding, thus running slower than normal. Either of these conditions is indicative of a problem that kills PCs - heat. Open the case and carefully examine the heat sink fins and the fan on the CPU. If they are caked with dust (especially the fins), then the CPU will likely overheat and shut down. Get some canned air designed for cleaning electronic components and blow the dust from the fins and the fan. Restart your system a see if the fan runs slower and quieter now, Machines that are in dusty environments, around smokers, or placed on the floor are especially prone to dirt buildup. Periodic cleaning with the canned air is the way to keep your PC happy and healthy.
Dec 10, 2013 | Acer Computers & Internet
Ford escape water pump
Replace the water pump
Jul 25, 2013 | Cars & Trucks
My computer powers up and the fan starts and then gets really loud and fast.
Is it the fan for the power supply?
I assume that you are talking about the fan getting really loud and fast. If you are taling about the computer, then I say turn the speakers down and load up a game as quick as possible cause you have a killer rig.
Oct 22, 2012 | Dell Precision 370 (370TREC) PC Desktop
The cooling fan is really loud and it has an
you can put lubricant oil on the center where you can found the washer holding the motor.
Apr 03, 2010 | Dell OptiPlex GX280 PC Desktop
Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Mar 12, 2010 | Whirlpool RBD305PD Electric Double Oven
Hi, we have a humming sound that is really loud,
Yes, its fan noise and you need to replace noisy fan.
Let me know exact model of your Sony TV and need to know what fan is producing noise to provide you part number and parts shop info to buy that fan.
Jul 31, 2009 | Sony Grand WEGA KF-50WE620 Television
HP Dv8233cl fan grinding
You only need to replace the fan, not the heatsink assembly.
Your computer repairer can do it or you can do it yourself once you identify the size of the fan and buy a matching one. You may have to solder a new connector on the lead.
Apr 15, 2009 | HP Pavilion DV8233CL PC Notebook
Noisy fan
Clean the computer from dust, use canned air to blow the dust out, as the airflow increases the fan wont have to run so loud.
if the fan is really loud, it needs to be replaced.
Aug 11, 2008 | Computers & Internet
MPC Computers ClientPro 375 (9557751) PC Desktop Logo
15 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Bee Santiago
T-Comtech Repairs
T-Comtech Repairs
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
