Question about Apple Iphone Mc640ll
How to remove cover to replace battery or SIM card
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Tip
How to SIM Unlock the Device CAT (Catapillar) B15 IP67 Rugged Android Smartphone
In order to SIM unlock this device, press and hold the Power key to turn the device off.
Note: A SIM card from another carrier and SIM unlock code are required. You will need to acquire a SIM unlock code in order to proceed.
Next remove the battery cover by sliding the lock to the right, then lift the cover and open at the bottom of the device.
Now remove the battery by lifting from the top of the battery.
Next remove the CBW SIM card by sliding it downward.
Push the new SIM card up into the slot.
now replace the battery by aligning the gold contacts on the battery with the contacts on the device and pressing the battery into place.
next replace the back cover and press the edges until they click into place. Finally slide the lock to the left.
Now you can turn the device on by pressing and holding the Power button.
Then enter the unlock code and tap OK.
You now have a SIM unlocked device.
on Dec 26, 2014 | Cell Phones
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
Nokia c7 sim card removal i don't now how ??
Insert the SIM card and battery
Important: Do not use a micro-SIM or a micro-SIM with an adapter in this device. This device does not support use of micro-SIM cards, and use of incompatible SIM cards may damage the card or the device, and may corrupt data stored on the card.
Follow the instructions carefully, to avoid damaging the back cover.
Safe removal. Always switch the device off and disconnect the charger before removing the battery.
1 Unlock the back cover release latch, and lift the back cover
2 If the battery is inserted, lift the battery out.
3 Insert a SIM card. Use the diagram printed on the device to correctly align the card.
4 Line up the contacts of the battery and the battery compartment, and insert the battery.
5 To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Nokia C7 (8 GB) Smartphone
I can't open my back cover...how can i change my sim
Hi there!
Let me give you the steps on how to insert the sim card on your phone.
First,kindly switch off the power and disconnect the charger and any other device before removing the covers. Avoid touching electronic components while changing the
covers. Always store and use the device with the covers attached.The SIM card and its contacts can be easily damaged by scratches or bending, so becareful when handling, inserting, or removing the card.
For you to be able to remove the back cover is that you have the press the back part of the phone gently and slide down the back plate of your phone.And after that kindly remove the cover and the battery.Please open the SIM card holder and insert the SIM card into the holder with the bevelled
corner facing down and the contact surface area facing toward the contacts of
the device. Close the SIM card holder.
Line up the battery contacts, and insert the battery. Replace the back cover.
That's it!
Thanks!
Apr 20, 2011 | Nokia X3 Cell Phone
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
How do you change the sim card
This phone doesn't have a removable simm card.
Oct 24, 2009 | Sanyo SCP-3200 Cellular Phone
Sim card installastion
1) Remove the back cover
2) Remove the battery
3) Look to the bottom of the battery compartment and find SIM card slot. The slot will be located between the silver metal and black plastic edge. Slide SIM card into this slot with the notch on the SIM to your bottom left. Slide in until it is flush with the edge of the black plastic.
4) Install battery
Replace rear cover.
May 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Apple Iphone Mc640ll Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
