Question about Datacard SP55 Plus Printer
Sp55 will not print on both sides of the badge even though the option to print on both sides is selected. Also for the other users it will print on both sides.
    New Friend:
  • 82 Answers
One thing is that you set both sides on the driver, other thing is when set by software( You need to check the option from both)
Posted on Apr 12, 2014
What is the code for the Emerson HDTV?
hyatis alt="Regular Contributor"> Regular Contributor div.custom-user-badges .custom-user-badge img{ float: left; max-width: 35px; max-height: 35px border: 0; } div.custom-user-badges .custom-user-badges-viewall { font-size: 12px; margin: 0px 0px 0px 10px }
  • alt="The Community would like to Welcome you!">
  • alt="Congratulations on receiving your first Kudos! Thank you for your meaningful contribution to the forum. May this be the first of many kudos.">
Member Since:‎03-10-2011 Posts: 69 Re: remote code for emerson hdtv [ Edited ] what remote do you have?
the best way is to try the search feature....Emerson tvs do not like comcast remotes... ive had a very low success rate. If its a combo emerson tv then i wouldnt even try.
This is for Red select button remote.
With TV on:
Hold down setup button while in TV mode till tv light blinks... Type in 9 9 1 then 1 again, press grey power button once then continue to press channel up button until the TV turns off. Hit setup to lock in the code.
DTA is the same except you just do 991 then start pressing channel up.
Go slow at first it is easy to skip past it and lock in the wrong code. If you press channel up for more then... lets say 2 min... then its not going to work.
good luck
Sep 16, 2015 | Emerson Televison & Video
Why can't I just print in black and white even though I am out of the Cyan toner for the Samsung CLX-3175FN
Dear user,
You have to select monochrome print settings first. go to properties of your printer and choose the tab where you get to select between B&W and color.
Aug 22, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
All I want to do is to be able to print off the whole manual for my 'Epsom DX3800 All-in-one printer'. I have already contacted Epsom several times concerning this and have not receive the help that I...
if you want print both side you need duplex printer. but you can print from normal printer also. for this you have to select odd option in printer window then print. by this way printer will print odd page numbers 1,3,5,7... only. after that flip printed pages and select even option in printer window. this will print even page numbers 2,4,6,7... by this way you can print papers both sides.
Mar 12, 2011 | Epson Office Equipment & Supplies
I have a Datacard SP55 plus and recently I started to get two white lines on the id card that I am printing and it goes right through the persons name so it is very noticeable I am not sure how to fix...
You have a physically damaged print-head.
The print head is in the cover and us user replaceable by pressing the lever inside the cover.
Print heads are considered consumables and need to replaced at maintenance. You can contact Datacard at there web site and they can have someone come out and change for, as well as service the printer. Or you can buy one online about $550 and change your self.
Apr 23, 2010 | Datacard SP55 Printer
Card jam in datacard printer
The rollers in the printer that move the card wear out and the rubber degrades over time, You need to have all the roller replaced and the printer should function like new. Contact MIdWestIDSolutions.com for pricing on parts or service.
Feb 19, 2010 | Datacard SP55 Printer
SP55 Datacard
The printer does not know the the model of the ribbon installed and thinks it is a monochrome (single color) Print ribbon. You can verify this in the Driver toolbox under the supply tab, or in the advanced printing options.
The Datacard SP series printers use an RFID Radio freq. tag in the take up spool end of the ribbon. This identify s the ribbon model and supply use settings for the printer.
Make sure you have the most recent driver and firmware from Datacard, There is a firmware Update Available to help reading "weak" RFID tag's
Next try removing the RFID tag from another (old) ribbon and see if it that fixes the problem)
Aside from that you:
May have a counterfeit (non-Datacard) ribbon
A bad RFID tag
Someone removed your RFID tag
You need a firmware update (weak RFID tag)
A bad RFID reviver in the printer, which is a fairly cheap repair.
Basically try a new print ribbon if that does not correct the issue, have the printer serviced.
www.TulsaBiz.net
Apr 07, 2009 | Datacard SP55 Plus Printer
HP 3600dn Duplexing Issue
Manual 2-sided printing. Most of the supported media sizes and types listed for printing from tray 1 can be manually duplexed. Do not use the 2–sided printing feature on transparencies, envelopes, or labels.
I found this note in the 3600 service manual. Maybe it will help.
Mar 06, 2009 | HP LaserJet 3600dn Printer
Can I print double sided documents with a hp 6310 all in one?
I don't see multiplexing as an option for your printer.
The manual way to do this though is to go through your regular print procedure but choose the option to print only the odd numbered pages and then simply put the printed pages back into the printer tray upside down (after giving them some time to dry) and then print only the even numbered pages.
Feb 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Badge labels
do you user manual? its in there
you can navigate by selecting bypass try first,select label printing
machine and printer setting must be the same,
hope that help
Oct 06, 2008 | Minolta C350 Color Printer/Scanner/Copier
Datacard SP55 Plus Printer Logo
60 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
jason
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
