Question about PfaFF Sewing Machines
My Pfaff Quilt Expression 4.0 feed dogs will not come up. I have cleaned the lint out from inbetween them, but it did not help. They move when you turn the machine on, but they never lift out of the down position.
  • PfaFF Master
  • 7,365 Answers
If the feed dogs aren't responding then they need to be checked at a sewing machine repair shop..
Posted on Oct 17, 2013
mohammed387
  • 1952 Answers
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Posted on Aug 26, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
RichSew
  • 184 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
  • 109 Answers
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Posted on Aug 23, 2010
  • 1788 Answers
SOURCE: pfaff quilt expression 4 It shreds
Are you using the right needles, size and type? Before, you wreck your material, take it in and have it serviced. I know everyone hates to pay for service, but if you like your machine it will be worth it to have it running at its peak. Just like a car, we spend tons on them but expect a sewing machine to never need anything. Remember, it is worth it.
Posted on Sep 13, 2010
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
NEED A MANUAL FOR PFAFF QUILT EXPRESSION 4.0
Just search the internet for:
Make + Model + the word "Manual"
Pfaff quilt expression 4 0 Manual
May 31, 2016 | PfaFF Sewing Machines
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
Seems to be too much gap between pressure foot and tension plate .. material is held loosely
Are the feed dogs completely up?
Are the feed dogs worn or clogged with lint and yuck?
Is there a presser foot pressure setting dial or knob?
Is the correct foot on the machine?
Is the presser foot correctly mounted?
Is the needle plate correctly mounted?
Jun 25, 2014 | PfaFF Quilt & Craft Pro 7530
Not sure what the problem is but you might try this:
Remove the top thread completely from the machine.
Make sure the machine is cleaned under the needle plate, the hook/bobbin area, the feed dogs, etc.
If your manual instructs oiling, do so as described.
Confirm that the feed dogs are in the raised position.
ALWAYS RAISE the presser foot then rethread the top thread from the beginning.
Verify the thread path is correct.
Confirm the needle is installed correctly (does the flat part face the right direction?). Is it the right needle for your machine.
Set the top tension to the midway point.
Check that the stitch length is set to at least #2.
Re-test your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
Some machines have a presser foot pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and the feed dogs. You may need to increase this pressure.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjUwYDwuKjVAhULwFQKHRLIA1YQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AFQjCNFFR0YpgCUh8R92wNbPzlJpuzWVNw
Jul 26, 2017 | Sewing Machines
Pfaff free motion sewing
Ok.. first understand that free motion is just that.... there will not be a perfect stitch length... You are the regulator of that as you move the hoop. You'll need to practice. There are some good videos on youtube on this.
Mar 14, 2013 | PfaFF Quilt & Craft Pro 7530
Fabric not moving forward, on pfaff 2048 quilt expression.
the feed dogs need to be checked to see why they aren't moving
the fabric like their suppose too
Jan 06, 2013 | Sewing Machines
Sewing Machines Logo
317 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
