Question about ReliOn Reli On Blood Pressure Monitor
Not giving accurate reading - ReliOn Reli On Blood Pressure Monitor
Invacare lynx4 shows full charge when I turn the key on when I turn the key off the charge goes to the yellow area either way the scooter won't move. Tried leaving key on no changes any ideas
Hi again U mentioned U left the key on,* some scooters have a shutdown circuit in the control box if u leave the key on for aprox 30 min it turns of. try removing key for a short time put it back ,& try it.we get the batteries load tested this will give U an accurate Reading on the condition of them the charge light on the scooter is not an accurate reading , load tester available on E/,,BAY APROX cost $35..... cheers
Aug 01, 2016 | Invacare Health & Beauty
What is the compression spec. for a Stihl 034 AV chainsaw?
Anything over 130psi is considered to be adequate compression
I usually give them 3 pulls, and take a reading, then do that another 2 times and average the 3 readings
May 14, 2016 | Stihl Garden
What should the cold compression reading be per cylinder on a 85 Honda shadow 500
There is none!
A compression test is done on an engine at operating temperature.
This allows the pistons, rings, etc., to be fully expanded, and to give an accurate reading.
Apr 18, 2014 | Motorcycles
Fuel gage showing half a tank but trip computer only registering 60 miles left
Its very simple. If the gauge is showing half full then fill the tank and see how much fuel it takes. If the amount you add is approximately 50 percent of the fuel tank capacity then you know the fuel gauge is accurate . In that case the computer is giving an inaccurate reading and should be ignored. All you need is an accurate fuel gauge - it does not matter a row of beans what the computer says if the fuel gauge is reading correctly.
Dec 22, 2012 | Saab Cars & Trucks
The torque ranges increase at what amount on the dewalt DCD920 cordless drill
I wouldn't count on those setting to give you an accurate torque reading, the torgue setting are so that you don't counter sink screws to far or strip the heaes. Obviously the setting go from zero to fully closed. the increments usually go by units of 10 ft lbs, but are not all that accurate.
Mar 21, 2011 | Drills
How to check youself / blood pressure for accuracy i get to different reading the first time then upon checking for accuracy the second time the reading is always different
Hello Dear
All Digital equipments vary in its reading. To get the accurate reading take three readings one after the other and then the average of the reading is the accurate one.
Usually the readings varies plus minus 2 or 3 to the accurate reading.
Hope the answer will help, please rate the answer.
Best wishes
Feb 23, 2011 | Lumiscope 1080 Deluxe Auto Blood Pressure...
I have OMRON HEM-650, but it does not give accurate results. Can you give me suggestion on which one is accurate and easy to take with? the brand, the model...
None of the finger or wrist cuffs are accurate. The slightest movement of your finger or hand will give a false reading. There are a few nice cuffs for your are and they are all pretty good. Relax for a few minutes before you take your pressure and ake it in the same position each time. Hold still and don't take a deep breath while it's testing. It is normal to have 20-40 points difference from one reading to the next. If it looks too high, sit still for 2 or 3 minutes and try again.
Oct 06, 2009 | Omron HEM 650 Wrist Blood Pressure Monitor
ReliOn Reli On Blood Pressure Monitor Logo
Top ReliOn Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a ReliOn Health and Beauty Expert? Answer questions, earn points and help others
