Question about Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive
Hi there, I am having problems with my brand new Verbatim Hard drive. I cant find the paperwork but the model is 64119 Verbatim 1TB. It was working fine for the last two months and I have just started to actually use it more often and now when I plug it into the usb port it says "The disk you inserted was not readable by this computer." I also tried it in another computer. My laptop is a mac book pro and the other comp I tried it in was also Mac. It used to work fine and now it is not being read. I have a lot of important things on it. Is there anything I can do to fix the problem without losing my files.The other problem is I purchased it in Australia and have now moved overseas.. so to take it back will be rather difficult.
    New Friend:
  • 30 Answers
Buy a new usb cable and try -it cuz they are damaged very fast .?
Posted on Oct 17, 2013
SOURCE: external hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Posted on Apr 10, 2009
  • 272 Answers
SOURCE: USB external hard drive does not show up on OS X desktop
You need to be sure that it is formatted as a FAT32 drive and not as a NTFS. When you are in Vista right click on the drive icon and click on properties. You will see NFTS or FAT32 under file system. Your drive must be FAT32 to be recognized by a Mac. Iomega.com has a FAT32 formatting software that you can download for free on your Vista PC and re-format the drive as a FAT32 drive.
Posted on Apr 25, 2009
  • 11 Answers
SOURCE: usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Posted on Jun 08, 2009
SOURCE: I bought a Verbatim Clon USB Portable HardDrive to
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Posted on Jan 16, 2010
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
Posted on Feb 23, 2010
Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
Dec 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I have a verbatim 2gb that cant be read sometimes it can sometimes not.
When it can be read, copy all the files onto your 'C:' drive.
Then, take a sledge-hammer to the Verbatim, to make sure that NOBODY will ever be able to read any files from it. Then, responsibly recycle it.
Spend $10 to buy a new 2GB device.
Dec 10, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Hi.. i hav a problem with Verbatim 8 GB usb drive,
they have lifetime warranty but not for the data. this is a damaged boot sector programming on the flash drive. It can only be recovered via a Level 3 data recovery company like ADR or Kroll. I used ADR.
Dec 28, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
I plug it in and nothing happens. Its brand new
When you plug it into your usb , goto My Computer , in the list of drives there should be a drive in relation to your usb drive.
copy your tunes and paste them right in there.
hope this helps
Dec 04, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim 4gb flash drive write protected error
your problem can not be solved, u can only buy a new one
Sep 01, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim drive regularly does not show up as available. I have to unplug it and try to get it to reset. do you know how to fix?
Hello!
I checked the Verbatim website for common Windows/USB drive problems. Since I don't know your exact model the information I'm giving is pretty general, but from the Verbatim website it looked like something that could help.
For one, Verbatim says you don't need drivers for your drive to work, but if you're having issues installing their driver might help. Go to their website (Verbatim.com) and in the top left go to "Support". From there you should be able to enter your model and download drivers. The installation instructions are usually on the same page.
The second potential fix is to increase the USB power to the drive. The Verbatim site says that some of their drives require plugging into 2 USB ports to get enough power to run the drive. If this is the case for your drive, you should've gotten a USB cable that is shaped like a "Y". The two wires at the "top" of the "Y" go into two USB ports on your computer. It also said that if even you didn't get the cable you could still be having power issues. You'll have to go to the Support section of the site and enter your model number to see if this could still be the problem.
Good luck! Remember to rate the responses you get!
Aug 10, 2009 | Verbatim External, USB 2.0, 750GB...
Opening travel drive on latptop
It will not work on any mac operating system. For some reason verbatim have configured it to only work on windows. I had the same problem. I just bought a new drive of a diffrent brand and it worked.
Aug 04, 2008 | Computers & Internet
Verbatim usb 160 external hard drive.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Verbatim Thumb Drive problem
You may need to log on to the computer with administrative privileges. Ask your friend to log you into the Administrators account, then insert the drive.
Sep 02, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Open Questions:
Plans For Online Storage And Online Backup - Dataalign Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
See all Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive Questions
Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive Logo
73 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
