Lanzar SDBT73N the preamp output dont wotk on my equalizer. But if i connect direct to the amp it work perfect...
    Master:
  • 482 Answers
Equalizers have a tape loop type input/output, there is a button to push that sends either the processed , or unprocessed signal through, check your connections again, power everything back up, and look for that button.
Posted on Oct 23, 2013
5 Suggested Answers
  • 54 Answers
SOURCE: I receive a radio channel in one of the outputs of the preamp
I would use sheilded wire on the mic with the least amount of cable. You can relocate the pre amp with aluminum foil wrapped around the pre amp. also turn the gain on the mic down as to eliminate any interference from your strong radio station nearby. Randy
Posted on Mar 13, 2007
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
ticthak
  • 43 Answers
SOURCE: i have a numark cd1 combo and i need to connect it my preamp and
1-RCA outs on the cd1, right? Route to ins on the preamp (use adapters if necessary, you don't say what pre and eq you have)
2- if the pre has an effect loop/aux bus or whatever, install the eq in the loop, and output the pre to the ins on the power amp; otherwise route the outs from the pre through the ins on eq then to power amp ins.
Posted on Aug 12, 2009
SOURCE: 7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Posted on Jan 07, 2010
Can you hook up a pyramid graphic equalizer 8600 to a Pioneer receiver audio video multi-channel vsx - D 912
The ideal way to do it is to hook up the preamp outputs of receiver directly to equalizer and the equalizer outputs to the amp inputs on receiver. Then unit will work with all sources.
Jun 30, 2016 | Pioneer Audio Players & Recorders
How to connect equilizer to mcintosh mac6700 receiver
Back of the 6700 - remove the links between Output 1 and Pwr Amp.
Use some phono/RCA cables. Connect from Output 1 to the equalizer's Input. Then connect from the equalizers Output to the 6700's Pwr Amp sockets.
Oct 19, 2014 | Audio Players & Recorders
On the back of the 6700 - remove the links between Output 1 and Pwr Amp.
Im trying to hook up a eq to my yamaha c80 preamp and dont have preamp out puts how do I go about doing it?
Hello Tom. The preamp outputs are on the right hand side of the back panel. You have normal and inverted outputs. These are RCA connections and should be connected to the inputs of an EQ unit. The outputs from the EQ unit are then connected to the input of your amplifier (c65) Perhaps I am misunderstanding youtr question? If I have not answered helpfully, feel free to ask further questions.
Cheers, Don.
Jul 07, 2014 | Yamaha Audio Players & Recorders
Graphic equalizer how to connect for my turntable to work with it
There should be the connections from the turntable connected to the input of the equalizer then the output of the equalizer to an amp
Some turntables require a preamp so refer to your turntable manual.
(Some equalizers act as a preamp) You wont hurt it by trying it.
Jan 04, 2013 | Mitsubishi Da-g108 Stereo Graphic...
My lanzar sdbt73n just all of a sudden stopped reading all disc. I need help
lanzar sdbt73n stop working. on the face plate the power button dont work. only way to turn on is using the remote. once turn on nothing works i.e. power, mute, open (for screen). the only thing that works is the volume knob. i have pushed the reset button but still the same.T73N S DefsdBT73
Jun 19, 2011 | Lanzar Sdbt73n Car Video Player
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
How to connect my realistic 7 bands equalizer to my amps .
Since you have not mentioned the amplifier I am not aware if the amp does have an preamp input and output. In case you have these then the output of the preamp of the main amp must be connected to the input of the equaliser and the output of the equaliser must go to the input of the main amplifier. The sources can be connected to the amplifer according to the selected device.If your amp does not have the preamp input/output then connect the source to the input of the equaliser and the output of the equaliser to the aux of the main amplifier.Now set your amp's bass and treble to mid point and set yout equaliser accordingly. Hope this helps. Good day
Jun 05, 2010 | Audio Players & Recorders
How do i connect my fisher equalizer to the amp model # CA-871
I assume this amp does not have separate amp and preamp.
(I cannot get the service manual for free...)
Connect the equalizer input to Tape OUT on the amp. Connect the Equalizer output to Tape IN on the amp. (Match up lefts and rights, eh?)
Now, when you press in the tape monitor button, whatever you have playing runs through the equalizer. Tape monitor button out, you hear the sound without the equalizer.
Mar 29, 2010 | Audio Players & Recorders
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
regards
Triarcuate
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
 Grubhead
Grubhead
