Question about Espressione Cafe Chic 1377
Cafe chic manual
The pipe in water container has come off where does it go
All lights are functioning but coffee is going directly into the dispenser. We tried to clean it but still same issue. Will it need a full repair or can we fix it from home
Try to put grinder (***** on top near cafe beans more to the right) on more rough. Choose less strong cafe and put cafe foam valve (if you have it) off (full left).
If problem persist, open the dispensing mechanism box, take all out, there is water dispensing pipe in the back (unscrew screws), take it out and clean it (the pipe should be hollow 5mm wide, it can take a day in vinegar to dissolve and/or water pressure and tiny *****-er to clean it).
Do the descaling&rinsing.
Try not to play around much as it might burn the pump.
Mar 18, 2016 | Saeco Odea Giro Espresso Machine & Coffee...
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Sunbeam cafe series EM 6910 coffee machine little red light keeps flashing
That's the low water warning, triggered by a black float with a magnet inside, in the water container.
The magnet inside the float in the water tank loses its magnetism with age.
Buy a replacement on eBay for a few bucks.
You cannot repair it, but the machine will continue to work fine without it - you just won't get a signal when your water is about to run out.
Nov 17, 2012 | Sunbeam Cafe EM6910
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
SC6924620
water pipe sistem empty when pres cafe making funy nois cafe button flahes
Mar 18, 2010 | Coffee Makers & Espresso Machines
On/Off switch for pump on Cafe Chic not working. Can I replace it myself and if so where can I get it?
Depending on the switch yes you can and most likely place to find a replacement is radioshak.
Sep 14, 2009 | Coffee Makers & Espresso Machines
Water suddenly started pouring out of the location where the water filter is connected. We checked and it is properly seated and screwed in. We had to turn the water supply off. This is a GE Cafe side by...
We had this happen several times to us, too. I finally figured out that anything that pushed against the filter would cause the collar to crack. It needed to be changed. My solution was to slip a simple plastic container around the base of the filter while I was replacing it and presto! The container does not allow anything to push up against the filter. Problem solved.
Aug 11, 2009 | General Electric Cafe CSCP5UGXSS Side by...
Water on cafe
May be too much coffee in the coffee container leaves water above the filter. Just a guess John
Aug 03, 2008 | Breville ESP8XL Espresso Machine
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Espressione Cafe Chic 1377 Logo
23 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
