Question about GE 19.5 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel
GDL20KCSABS CLICKING, CAN GET IT TO STOP BY TURNING FREEZER CONTROL TO OFF.
3 Suggested Answers
SOURCE: GDL20KCSABS bottom freezer loud clicking in back/lights blinking
GE apparently has the same issue with power supply capacitors that plagues the computer industry. I have fixed 2 GE refrigerators motherboards with the clicking relay issue in the last year. Look for the bulging/leaking capacitors by a small transformer in the power supply section of the motherboard. These caps were labeled C29 and C30 and are 470 UF 25v electrolytic radial lead caps. Can be purchased a radio shack for about 2 bucks. These caps are easy to replace with simple soldering skills. My fridge is about 3 years old.
Posted on Dec 30, 2009
  • 230 Answers
SOURCE: What's your problem?GE Model # GDL20KCSABS clicking sound Clicking sound
The clicking noise would generally be the overload on the compresser. Which means the compresser is locked up and unable to pump and needs to be replaced. Sorry You can install a 3in1 hard start which may free the compresser rotor and give you a little more time out of it but will need to be replaced eventually Good luck
Posted on Sep 08, 2012
Frigidiare lffh21f7hwa freezer When door is opened light will flash on and off you can hear a clicking sound, every so often it will have to be reset by unplugging
You are talking about the inside light right? The clicking is coming from the controls panel right? I think the problem is related to the control board itself because there is a relay that switches the light on when the door is opened part number=> 297366300 Frigidaire Freezer Main Control Board Otherwise if removing the bulb will stop the problem, please try that. Appliance 911 Sea Breeze
Dec 06, 2015 | Refrigerators
The bottom of my refrigerator remains warm despite turning the knob to MAX.
If it's frost free check that the fan is running in the freezer section.
If ice is causing it to stop then it your defrost control that is causing the problem
Jan 09, 2014 | LG LRTBC1825T Top Freezer Refrigerator
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Sep 08, 2012 | GE Refrigerators
My GDL20KCSABS fridge is out. The lights are on, but the compressor nor fan are working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Oct 24, 2010 | General Refrigerators
Hi i have a ge fridge,about 3 years old model #gdl20kcsabs it started making a clicking sound and started defrosting everything. it has also been getting very hot on the outside bottom freezer panel to...
Clicking sounds (not immediately preceeded by a power loss) indicate a bad relay on the mother board. Replace the mother board, WR55X10942)
Aug 21, 2010 | Refrigerators
Ge model GDL20KCSABS refrig portion went to 50 degrees. Had service and they replaced main board. worked 3 months and refrig went to 50 degrees again. serviced again and now it is 28 degrees in the refrig...
It may not be your main board this time. Let me do some study on your design. I need to find out if you have a auto damper or just what so please communicate before you rate as it may thake some study through the morning for me to home in on the cause. I will be back soon, Sea Breeze
Feb 03, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Clicking noise will not stop
Clicking noises usually come from the electronic control boards or mother board. Usually means it bad.
You can hear the fan clicking if it's hitting something like ice buildup.
Oct 18, 2009 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
The control board is going out . Pt # WR55X10656 . Soon , you will start having a refrig problem . Probably already started , but , not obvious yet .
Aug 26, 2009 | GE Refrigerators
you have a bad motherboard the clicking noise is coming from the lights relay. the part# is WR55X10656 it is a plug and play part so you can do it yourself. I got your part number through partsdirect.com its about 130.00 you maybe able to shop around and find a better price. thx for usinf fixya peyton.
If my solution helped pls rate me accordingly..
Jan 30, 2009 | GE GBS22HCR Bottom Freezer Refrigerator
GE 19.5 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
